diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
are 12" subs better than 10"? - Click HERE for Original Thread
bykerlucky13
I am thinking about getting 2 new subwoofers,i wanna know what would sound the best 2 10"s at 500 watt rms each or 2 12"s at 600 watts rms each the subs are both ma audio with a ma audio 1200 watt mono amp! im looking for the best sound
Stocker
There is not better, there is different. conditionally.
Cal Weldon
What kind of car and what's the difference in price?
justonemoreamp
quote:
best sound ??? try looking at Phoenix Gold RSD line woofers and amps. Nice stuff and SQ rated equipment:)
try Amp guts.com and Phoenix Gold .com
best of luck on your system :)
bykerlucky13
i have a mk2 jetta the 12s im lookin at are 145 each and the 10s are 130 each
boxcustom
TENS ARE BETTER THAN TWELVES. IF YOU BUY TENS, YOU WILL HAVE ENOUGH CHANGE FOR A COUPLE OF STEAK DINNERS. If you have the power for 12's and the proper airspace they will put out lower bass and more sound pressure. However if you do not have the room for a larger box (enclosure) I recommend 10s. IF YOU DO NOT HAVE THE ROOM FOR TWELVES BUT STILL LIKE LARGER WOOFERS, USE 10'S AND USE 12 INCH SPEAKER COVERS.
xplod1236
Look into going with a single 12 or a 15 instead of dual 10s or 12s.
quote:
In what way?
If you like large woofers, getting large grills doesn't help in any way. If you like the "look of large woofers," then yes, the grills help.
sid216
Personally, I like 10's the best. With the right box, right amp and the right subs, they will go very low and loud. Like rock concert loud.
I just got a '97 Kia Sephia and I'm going to put my Dr. Crankenstein HV 12's in it on the fact that the rear seat folds down. I don't plan on having passengers in the back much so I don't care.
I just need to figure out how to motorize the rear seat so it folds down. That and the stock mid locations suck, doing a stealth install will prove a challenge...
bykerlucky13
i dont care about spae the subs i wanna get are good not mounted in a box (free aire space) plus i have a big *** trunk so saving space isnt an issue im thinkin about fully customizing the trunk anyway and not useing a box just need to know which gives off a nicer sound before i buy em!!
Page generated in 0.063922882080078 seconds with 17 queries,
spending 0.00993681 doing MySQL queries and 0.05398607 doing PHP things.
Please support our sponsor.
