diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Chipamp won't work! AARGH! - Click HERE for Original Thread
Spasticteapot
My latest attempt at a LM3875 chip-amp still won't work. You can see pictures below. (I'll add the PCB design and notations later.)
Can anyone tell me how I screwed up?
Spasticteapot
Pic #2:
Netlist
Really hard to tell but I believe you should try to improve your solder skills. :)
If the supply voltages are correct, measure every trace with an ohmmeter to make sure everything is conducting the way it should.
/Hugo
Spasticteapot
/Hugo
I should also probbably get a better soldering iron tip. Or a better soldering iron. (The crappy PCB does'nt much help, either.)
Netlist
Yes, a good soldering iron is a Diy-er's best friend. You invest once, you have lifetime pleasure. :)
/Hugo
drummer_Dave
Just remember if you are measuring the traces with an ohm meter MAKE SURE THE POWER IS OFF!!!!!!!!
Netlist
Good point; and caps discharged.
/Hugo
v-bro
Am I wrong or is one of them two larger electrolites connected the wrong way'round?:confused:
v-bro
And? :confused:
karma
it would have been faster to p2p it;)
Spasticteapot
quote:
Once I get the @$@$ing PCB worked out, I'm going to have Olimex make me a bunch of 'em.
GG
With the LM3875, P2P is a good choice. This site is shows a simple P2P build in small steps.
http://www.vikash.info/audio/gainclone/
Good luck and don't give up.
Spasticteapot
After diagnosing the problem to be a fried capacitor, I simply removed the Zobel.
The amp works!
However, there's an odd problem: I think I'm only getting half of the signal (0 - +30 - 0 - (should be -30 ,but is 0) - +30, et cetera.) When I unplugged the amp and it was running off of the power filtering caps, the volume and sound quality doubled, and the nasty distortion disappeared.
I'll be replacing my rectifier, and if it works, I'm off to Olimex! Woohoo!
drummer_Dave
Congratulations!!!! Its great to hear you got it working, just a little time and perseverance. way to go
Page generated in 0.030057907104492 seconds with 17 queries,
spending 0.00764990 doing MySQL queries and 0.02240801 doing PHP things.
