diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
How big of an amp can I make with this? - Click HERE for Original Thread
ew
Greetings, I recently picked up a rather large transformer 30-0-30 670VA & am looking to make a ridiculously large chip amp. Any ideas?
SpittinLLama
at 30-0-30 the supply voltage will be pretty high so you will probably need to run into 8 ohm loads unless you parallel some chips. If you went with straight LM3886 you should be able to get 6x60W into 8 ohms, give or take. So 360W of output power. If you wanted one large amp then you'd need to do 4xLM3886 bridge/parallel (BPA) or a 6 chip version, 3 in parallel on each side of the bridge. Just some ideas. Power output is a guesstimation.
-SL
AndrewT
30-0-30Vac would be a good start for a 4ohm amplifier.
BUT
It would better suit a discrete design with that sort of voltage.
Parallel pairs or triplets of chipamps starts getting beyond the simple intention for using a chipamp.
working backwards from your transformer rating
670VA supports about 420W of output power.
This could be 210W+210W into 4ohm
but this needs 35-0-35Vac to get the necessary DCrail voltage.
or
140W+140W+140W into 4ohm. That is about perfect for 4ohm drivers and running on +-44Vdc
Ah! a three channel front of house amp for a 5.1 system.
ew
the 140x3 sounds interesting & just oddball enough to get my attention. Would how many LM3886's per channel would such a beast require? thanks again!
AndrewT
how many? a lot! an awful lot!!
and the voltage does not suit chipamps.
Have another read of the datasheet, particularly the
supply voltage vs load impedance
and dissipation/heatsink vs (load + voltage).
ew
Could the high voltage be taken care of by using a regulated ps? Also, could I use something like Brian GT's LM3886 Stereo Kit x3, one for each channel to keep things simple? Thanks again.
jaudio
This is simple
http://www.diyaudio.com/forums/atta...tamp=1114046322
http://www.diyaudio.com/forums/atta...tamp=1114369981
This post will explain implementation
http://www.diyaudio.com/forums/show...t=&pagenumber=1
Parallel as many as you like. I went up to four with good results.
You will have to find a really high current regulator. There are people on this site, who reported using +/-42 volts without problems
Page generated in 0.024090051651001 seconds with 17 queries,
spending 0.00749159 doing MySQL queries and 0.01659846 doing PHP things.
