diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
3pin capacitors - Click HERE for Original Thread
Tenson
A quick question, what is the point of 3-pin capacitors? Is it essentially two caps in one package to save space?
Cheers!
pinkmouse
Some three pin caps just have an extra NC pin for more secure fixing and to make sure they are not inserted on the PCB the wrong way round.
Tenson
You say 'some', what are the others?
The ones I have have the pins labelled '1', '2' and '-' which is ground.
Nordic
just take a 9V battery and see which of the pins will hold voltage between them after you remove it...
dswiston
Could they be X2Y caps? X2Ys have "four" terminals but two of them are/should always be grounded (connected together), so its like they really only have three.
BTW, X2Y caps are a new type of cap designed to have ultra low inductance so they work well for very high frequency duty caps.
Google for x2y if you're interested, there is plenty of info on them.
dswiston
It just crosed my mind, unless you are talking surface mount, they are probably NOT X2Y. . .
Page generated in 0.022521018981934 seconds with 16 queries,
spending 0.00927806 doing MySQL queries and 0.01324296 doing PHP things.
