diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
bridging a 4 channel amp - Click HERE for Original Thread
fearless_gamer
Hello everyone, i was wondering if it is possible to bridge a 4 channel amp into one channel? unfortunatly i kno nothing about the amp, i never herd of the brand and cannot find it anywhere on the internet but i do kno that it is a GSpot with model number 1004T and is 4 channel bridgable into 2 channel and im only running on one of those channels but i am trying to get the most out of the amp. I searched and i came up with something but im not too sure about it. Here is what i found http://www.wikihow.com/Bridge-an-Amplifier
richie00boy
No is the short answer.
Perry Babin
That amp was made by Mark Antony amplifiers (no longer in business).
The best you can do with a single speaker is to buy a dual voice coil speaker and drive a bridged pair of channels to each coil.
fearless_gamer
ok thats all i wanted to kno, thanks :)
fearless_gamer
I forgot to add in that i have 2 12" 1000 watt koiiler XM-8212 DVC subs (which i also never heard of) and i have them wired for 2Ohm load but that is only if i have them both on the same channel, from what i understand they both have to be wired together onto one channel in order to get the 2Ohm load....also does anybody kno the specs of that brand amp?
sr20dem0n
So why don't you just split the subs apart and use one per bridged channel?
Most amps don't appreciate a 2 ohm load when bridged...
fearless_gamer
Well, i did have it that way but from hours of searching and reading and looking at the setups on the rockford fosgate site i gathered that they will be running at 8 ohms while connected like that and the amp is min 2ohms bridged..on the configuration wizard and other diagrams i looked at i assume that they are wiring as if connecting to one channel or a bridged channel... Is it possible to wire the subs as 2ohms each?
fearless_gamer
Im sorry, i had a typo...the amps min is 4 ohm bridged, i am unsure how to edit the posts, so i have to post again... But i want to get the amp to see a 4 ohm load and the way that u suggested to have it wired is the way i believe is making it see an 8 ohm load, but i also could be trying to get it to do something that the whole thing cannot do... I am new to the in depth technical parts about this, as far as ohms and whatnot.. so what i want to get it to do is read 4 ohms to each sub on each channel and then i should get the most out of the whole thing.. I think anyways :)
sr20dem0n
quote:
What is the impedance of each sub?
If you can have them wired together to a single 2 ohm load, then you can have them wired to 2 4 ohm loads, and put each of them on their own bridged channel.
fearless_gamer
each sub is 4ohm dvc
sr20dem0n
Then the best you can do with that amp is wire each sub in series and put them on the bridged channels individually.
You probably have them wired to a single 4ohm load on one bridged channel currently, which will give you almost as much power as the above suggestion and is harder on the amp, it would be better all around to split them up and run each bridged channel at 8 ohm.
xplod1236
Why not run the 4 VCs on 4 separate channels?
sr20dem0n
quote:
Same result as wiring in series and bridging the amp, except if you bridge the amp, any differences between the channels will be cancelled out before they're sent to the sub, instead of being sent to the sub and being cancelled out in the sub's electro-magnetic field (which means you're wasting power).
richie00boy
Not only that, but bridging can potentially offer a slight reduction in distortion due to even harmonic cancellation, and generally loads the PSU nicer as it keeps high current flowing in and out of the amp outputs instead of ground.
fearless_gamer
Thanks for all the help..i didnt realize that there was another page (stupid me lol) lol....what is kind of confusing is that i cant wire them to run at 4 ohms on single sub but i can run at 2 and 8 ohms but if i wire them together i can get 4 ohms :confused: also would anybody kno how i can find out the amps power rating? or the specs on it?? (Gspot 1004T)
Page generated in 0.039757966995239 seconds with 17 queries,
spending 0.00995755 doing MySQL queries and 0.02980042 doing PHP things.
