diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Would this work - Click HERE for Original Thread
lykkedk
OK, I give up, I just dissasambled my entire PCB, for the balanced line stage, planning to make a complete new design, unbalanced only.
I have found this schematics (Thank's to the author),
Would this work ???? ( The one I had redrawn ? )
lykkedk
And the Schematics I had found is this :
lykkedk
And connected like this to RCA :
2Bak
this will work fine
lykkedk
quote:
Originally posted by 2Bak
this will work fine
OK THANX
analog_sa
This will work but you'll get better results if you retain the gate stopper and connect to ground through a similar resistance as the i/p mosfet. Differential amps achieve best CMRR when both inputs are driven by equal impedances. Also may be a good idea to retain the trimpot.
cheers
peter
lykkedk
Thanks, but could you perhaps draw that in on my schematics, cause I don't understand all of this !!!
Electro-Nick
Only a few more modifications and you would have a Bride of Zen ?
Why all that trouble, i would go for a BOZ right away if only unbalanced is needed.
Gr,
Nick
lykkedk
Gr,
Nick
Cause I think, the balanced, is better as unbalanced, than the BOZ
Circlotron
Referring to the schematic in the first posting, seeing the Q2 drain signal is just an inverted but equal amlitude version of Q1 drain signal, it doesn't appear that Q2 is really doing anything besides making the schematic look pretty. You could probably just take the signal from Q1 drain and throw Q2 and it's extra pieces away! The total source resistance may need to be altered because there is now only half the current in it.
eLarson
quote:
Using only half would yield a Bride of Zen for all
intents and purposes.
Looking at the first post again, though, I see a
Source-follower (Q1) driving the Source of a
common-Gate stage (Q2) to give a non-inverting
configuration.
It might sound a little different from a Bride of
Zen, but I can't say from experience: I haven't had
the time to build the balanced Zen linestage yet.
(The fact that I've been really pleased with my BoZ
all this time hasn't added any particular urgency,
either.) ;)
Erik
jh6you
If we manage to remove R1, too, from the originally-posted schematic (single-ended input and output), we could beat the Miller effect and so improve the input rolloff frequency.
JH
Circlotron
Just keep on snipping out parts till it stops working, then go back one. ;)
Page generated in 0.033998012542725 seconds with 17 queries,
spending 0.00959373 doing MySQL queries and 0.02440429 doing PHP things.
