diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
What is a solid state relay? - Click HERE for Original Thread
Bronze
A relay to me is a purely mechanical device. Is this another name for an SCR?
jserrano
The solid state relay (SSR) is the electronic equivalent of the electromechanical type.
Take a look at this picture and it will seem clearer.
http://www.ifirobotics.com/images/ssr_600w.gif
Brian Brown
quote:
A solid state relay is a pre-packaged electronic module that can take the place of a traditional mechanical relay.
Typically the input feeds an optocoupler which, depending on the load, controls a Triac, SCRs, MOSFET, or IGBT. Sometimes there's extra circuitry to handle transient suppression.
Note that solid state relays are for AC or DC, but not both.
Brian.:cubist:
Nelson Pass
Also, don't even Think of sending an audio signal through one.
Brian Brown
quote:
Yikes!:yikes:
It never even occured to me that somebody might want to try that!
But now you've got me thinking about it.:boggled:
Havoc
There are some small opto-coupled SSR's that can be used for audio. You do not use a 10A relay for audio do you?
Something to consider when using them: they do not provide galvanic separation like "real" relays do. You always have a leakage.
peranders
Nelson, this is not so crazy as you think. I'm not totally sure but I have a vague memory of a solid state relay with double MOSFET's. But still it's pretty crazy....:hypno1:
Page generated in 0.078433036804199 seconds with 17 queries,
spending 0.03058815 doing MySQL queries and 0.04784489 doing PHP things.
