diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
BoZoS unbalanced again. - Click HERE for Original Thread
lykkedk
Hi again, I wrote this new thread, cause I think someone might have misunderstod my quistion.
I'am just building this Balanced Line Stage, which I plan to use, for preamplifieng, lines from my CD, Computer, DVD etc...
None of theese, seem to be balanced equipment.
My CD is a SONY X55ES, which I will connect through GoldPHONO'S (RCA), the output will be golded too. The rest of the input RCA's will be cheaper one's.
The output should go to my Leach-amp which I think have an inputimpedance around 20kohm. The Leach amp is with one powersupply, and two mono-block's, with one RCA for LEFT input, and one RCA for RIGHT input.
I made a little change to the PCB for the line stage, so I could use 1,5k/11w ohm resistor instead of the two 750ohm/3w one's
Actually I have used a lot of time making the PCB (Handmade), and I allready soldert most of the component's to it, hoping to use it unbalanced without making any changes on the PCB, and component's used.
I was planing to use a stereopot for P3/P4, for volume control.
This is, what I really wanna know, so please HELP...
Howto use it unbalanced, maybe with some grounding at -IN, and -out, really i do not know howto do this...
What about R15, I use 124ohm. is this right, when not using P1, and P2.
Well I had not yet bought any pot's, so I am open to any suggestion's.
Henrik
lykkedk
You simply short -In to ground with wire.
I wouldn´t short the unused output to ground, no need for that.
R15= 124 Ohm is ok!
Lower the gain as much as possible by increasing P5, this way You get the lowest distortion.
lykkedk
[Then I only have to short -IN, and use GND / +OUT, to the female RCA (Phono) ?
What about C1 R9 R11, I dont have to use at all ?? , or could I just leaveout C1, cause I allready soldert the R9 and R11, into the PCB. The reason I ask about leaveout C1 is, that they're pretty big. (Would leave me more space for only one of them) javascript:smilie(':bigeyes:')
I wasent thinking, of using P5, I just want to make a short here, that's why I quistion about
R15, because I have seen some schematics, where 430ohms where used in unbalanced operation.
Henrik
Yes.
Those You don´t need, unless You some day wants balanced operation.
Try some diffrent values, I think You will need about 350 Ohm for R15, but that depends.
2Bak
If running unbalanced only you will not need a pot at P3 but at P4 only (e.i. a stereo-pot for both channels). However if you plan to use - out later (balanced out), then think twice before you buy the pot for P3, cause a stereopot cannot be used as pot for both P3 and P4. Only a 4-channel pot or attenuator can be used for that (balanced).
lykkedk
Yes sure, P4 only
Page generated in 0.026985883712769 seconds with 17 queries,
spending 0.00677013 doing MySQL queries and 0.02021575 doing PHP things.
