diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Low ceiling remedy for “Dumbass” - Click HERE for Original Thread
marekst
Dumbass
Sorry I moved this topic from speakers’ forum.
The diffusion system installed on my ceiling is the least scientific part of my system. I call it LSD - lunatic sequence diffusor. I used whatever wood I had left over after building my house. I made random peaces, 2 of each, and screwed them to the joists with the left side being a mirror reflection of the right. My ceiling is high and sloping down towards the speakers so I do not need much diffusion and low efficiency solution like this is OK.
If you have low ceiling the most efficient thing would be broad bend absorbing panels of rigid fiberglass about 4”x24”x48” installed on the ceiling at first reflection points. You can add diffusion to your room at different locations. The best way to learn about this subject is The Master Handbook of Acoustics by F.Alton Everest. This book should be in every audiophile’s library.
Marek
http://gallery.audioasylum.com/cgi/...serImages=21150
Dumbass
Thanks for the thoughtful reply. I'll look for that book.
Page generated in 0.025569915771484 seconds with 17 queries,
spending 0.00971842 doing MySQL queries and 0.01585150 doing PHP things.
