diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Directionality of V-Cap TFTF? - Click HERE for Original Thread
Colescuttle
I just found a set of V-Caps in a "parts only" amp I received in trade. Is there a preferred orientation (directionality) when using them to bypass power supply electrolytics?
Thanks.
George
KBK
when you are holding the cap in your hands, looking at the label, and the words are correctly laid out in front of you (a lead out the left and a lead out the right), the left lead is the outer foil, or the positive (+) terminal connection.
Page generated in 0.017023086547852 seconds with 16 queries,
spending 0.00849199 doing MySQL queries and 0.00853109 doing PHP things.
