diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
Perry Babin ORION 225 - Click HERE for Original Thread
shallowfu
Perry Babin, Can you help me?I need a picture of a 2nd gen 225 orion.I removed mosfets,ref,outputs a long while ago and forgot where they go.I have has this board laying around for awhile.A picture or just placement,Thanks again!
Perry Babin
http://www.bcot1.com/canons3macro/225/IMG_4062b.jpg
http://www.bcot1.com/canons3macro/225/IMG_4063b.jpg
http://www.bcot1.com/canons3macro/225/IMG_4064b.jpg
http://www.bcot1.com/canons3macro/225/IMG_4065b.jpg
shallowfu
Thanks,I had it laying around for awhile and it was stuck in clipped.I replaced everything but, clipped told me maybe replace the op's because thats the only thing i haven't changed.I'm going to put evrything back on and see what happens.Do you have a lj 500.1 insides pictures?Amp guts didn't help.
Perry Babin
What section?
The smd parts require tight shots to be usable.
shallowfu
Perry Babin
http://www.bcot1.com/canons3macro/jl/IMG_4091b.jpg
http://www.bcot1.com/canons3macro/jl/IMG_4092b.jpg
Let me know if you need any others or if these missed the actual components you need.
shallowfu
Those were perfect and i picked the board up in ebay.It was all there but, those parts.It looks worth making it a diy project or if i can get a sink.What do you think of it?
Perry Babin
I think you should get it working before you spend any time looking for a sink.
They're generally easy to repair (because the problems are generally simple). If the board isn't damaged and the output inductor isn't damaged, you should be able to get it going.
shallowfu
I have stacks of many brands of boards over the years bought on ebay and other but, the outputs were bad only and i think someone just parted it a little.Thanks to you i will get those parts next time a put a order in and see what happens.If it doesn't work it doesn't matter it was bought for parts anyways.
Page generated in 0.025681018829346 seconds with 17 queries,
spending 0.00816774 doing MySQL queries and 0.01751328 doing PHP things.
Please support our sponsor.
