diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
8P Din Cord for Nakamichi Stereo - Click HERE for Original Thread
gixxer1k
I was wondering if anyone knew of a place I could get an 8P Din Cord for my Nakamichi Stereo. Here is a pic of the connection. I called Nakamichi USA and they referred me to the parts department and said the cost would be $128!!!! Is that correct? Its just a simple cord. What are your thoughts?
Lord Winter
Hello Gixxer !
That connector is "mini-DIN". Nothing really special. $128 is a true rip-off for that replacement cable !
I advice you to start experimenting, and make a cable for yourself !
Regards.
neutron7
That does not look the same as a normal 8 pin din. the 2 rows of 3 look the same length, where normally they are spaced differently. possibly this has been done to force you to buy that cable.
http://www.answers.com/topic/mini-din-connector
what does that cable do anyways?
Spasticteapot
When all else fails, use a standard 9-pin serial connector.
Geek
Those were used on ancient Logitech mice too. Check at a second hand store for one.
Spasticteapot
quote:
That's not a PS/2 connector, if that's what you're thinking. Mini-DIN's are a bit more rare.
Geek
quote:
Nope, pre PS/2 connector... think mouse card for '286 and 8088. I had one ;)
isival
I need the same cord . Did you ever find it ?? PLEASE HELP
Page generated in 0.025495052337646 seconds with 17 queries,
spending 0.00773478 doing MySQL queries and 0.01776028 doing PHP things.
