diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
symmetric amplifier - Click HERE for Original Thread
Rambi
Dear all,
Over the last few months I've built several prototypes of power amplifers. I started with OpAmp driven circuits (which sounded OK), but decided to try a SS design as well, just to be 'sure'. The first (working :headbash: ) protoype sounded so much better I decided to stick with that (this is personal preference of course, besides I can only compare it to an 8 yr old Phony(TM) audio set).
From various sources combined (mostly Elektor) I ended up with this design for a symmetric (class AB) power amplifier.
The only difference between this one and my last working prototype is the Vbe multiplier (prototype has trim-pot between C and E) and the end transistors (BD911/912 instead of Sanken types since BD91x is somewhat cheaper to experiment with, although I did use the Sankens in a version without the cascodes in the LTPs successfully).
I would welcome any thoughts :scratch2: or comments you might have on this design.
Thanks!
Remco
P.S. One thought already: R2 & R102 are probably superfluous, the reason I kept them in was because I like to stick as much maybe's in a PCB design as possible, it's always easier to leave components out and bridge them than to insert new components in an exisiting PCB ;)
Rambi
Ooops...
Comment about the Vbe multiplier should be:
prototype has trim-pot between C and B (not C and E).
Sorry about the zipped PDF, but it's the only way I could get a decent picture :xeye:
Remco
vbd
My 2 cents (of Euro, of course...):Q3,4,and 6 (and 103..etc..) dont have to be BC546-556, as they are cascoded and see only small voltage. It is better for gain and offset to use high gain transistors BC550-560, for instance...
dimitri
It is bad idea to shunt Zener (LED) by a capacitor. The capacitor will not filter unwanted noise because of the low dynamic impedance of the Zener (LED). For reducing hum you can split R7(R107) as 5.1k + 5.1k, and connect C4 (C104) (better 100u) between supply rail and the common point of 5.1k resistors. If you aware about hf LED noise, you can use R-C filter, i.e. put an extra resistor between D1 and base of Q5 and reconnect C3 between supply rail and base of Q5.
The voltage swing on the Q8(Q108) base will be limited by (30-UD2-0.7)=25V. The excess voltage drop on the output device will be 10V at maximum current, would you like to warm up your room? Your 30V supply should be 40V.
Why do you use emitter bypassing in Q6(Q106)?
dimitri
oops, R56 should be ten times lower
halojoy
quote:
Originally posted by Rambi
Dear all,
Thanks!
Remco
I had a look at your amp.
I like it.
BD911 are good working horse devices.
Can take a lot of heat for being TO220
A choice I also like.
Regarding the details you will get more opinions
by others.
Enjoy your project.
It is yours!
traderbam
You have done your homework!
My only suggestion for now is that you try this and see what it sounds like: Remove R56 and C51. Add 100 ohm resitors between Q9 base and emitter and Q109 base and emitter.
I believe you should have decoupling across your CCS LEDs - it's nothing to do with LED noise as you probably already know.
BAM
Rambi
C6/C106 bypasses R8/R108 for audio (but not for DC), seems to give it more 'oomph'. Since my latest PCB has Q7/Q107 mounted directly to the heatsink I could probably just as well lower R8/108 and ditch the capacitors.
Using a cascode will not change the voltage drop over, or power disipation by, the output devices, that's determined by supply and output voltage (and of course the kind of load). It does limit the maximum output swing by a few volt, but I figured that disadvantage was compensated because it allows me to use BC5x devices in the VAS.
As for the supply: I use a 2*30V toroid, after rectifying etc the output voltage is more like 40V (slightly higher even).
R56 can be a factor 10 lower, I'll try it and see (hear) what it does to the sound.
Thanks for your comments!
Remco
Rambi
BAM
I'll try a lower value for R56 (appr. 100 Ohm instead of 1200) first, since that's easier to do. Using two resistors and connecting the 'middle' to the output (like you describe) is one of the 'options' I did not include in the PCB design (but should have...). Anyone out there ever tried and compared these two variations? (fig.13 A and B from http://www.dself.demon.co.uk/dipa.htm#5 )
Thanks!
Remco
dimitri
Yes, I’d tried and compared these configurations many many years ago… I can address you to my article "Building Better Buffers," Electronics World + Wireless World, 1992, Nov., pp.931-934.
Yes, Mr.Self is right, that his Fig.13(b) gives much better turn-off, but another drawback of Fig.13(a) is that the driver transistors will also switch off, after the output ones, one more singularity! In Fig.13(b) the driver transistors will work with nearly constant collector current (class A) during the whole cycle.
sonnya
I do not agree totally. Its okay to remove C2 and C102 but keep C3 and C103.
Why?
To bypass the LED's at high frequency so you not only have a low impedance at LF but also at HF.
Then again split the circuit as Dimitri says but reduce the R in the RC filter to 10 - 20 ohm to prevent making a resonance circuit with C3 and the LED.
Be carefull with large size film caps like C51. Larger values more series induction.
Add a small base resistor (1 - 10Ohm) on Q9 and Q109 to prevent oscillation in the output devices.
The i can only say.... Nice circuit!... go build it.
Sonny
dkemppai
I'm currently in the process of building a similar amplifier. Just curious, do you have any gain/phase plots or scope pictures of sine/triangle/square waveforms at test frequencies? Say 1K,10K,20K, 50K, and 100K @8Ohms load or so. Also have you tested stability with any comples loads?
I'd be really curious to see how your amp responds.
Also, Am I mistaken, or is the LF411 an integrator to compensate for the DC-Bias? I'd never seen that done, but I've been thinking about trying it (Soon). :) :) :)
-Dan
Rambi
Umm, no sorry. I do have a scope, but no digital camera.
(And at the moment the design is still changing rapidly enough not to use an ordinary camera, certainly with the excellent feedback and fresh ideas from this forum, thanks all! ;))
Good idea though, I'll see if I can beg, steal, or borrow a digital camera for the final design (which should be around the time pigs fly, there's always another tweak to test...)
The only complex loads it has seen are various el-cheapo loudspeakers each with variyng qualities of cables (don't have a power resistor).
Out of curiosity: is your amplifier project already in a stage where you have any schematics (that you'd like to share)?
-Dan
Yep, it is. One of the earlier design I tried to build was the Elektor HexFet power amp, which doesn't use such a DC compensation circuit. It did work, but the DC offset was too unstable to my liking (nice to see the effect of breathing on the LTPs though ;)).
This circuit seems to do the job quite nicely and as a bonus it eliminates an electrolytic in the feedback path. Downside is that it needs a capacitor at the input, but that doesn't have to be as big (or an electrolytic). Come to think of it: It should be possible to connect it to the other side of the LTPs with some tweaking.
It does need a few seconds to stabilize at startup (depending on component values & matching, latest one starts from appr. -1 V and needs a few seconds to get close to zero).
Remco
dkemppai
b]Good idea though, I'll see if I can beg, steal, or borrow a digital camera for the final design (which should be around the time pigs fly, there's always another tweak to test...)
The only complex loads it has seen are various el-cheapo loudspeakers each with variyng qualities of cables (don't have a power resistor).[/b]
Tell me about the tweaks... ...I've got an amp that's almost done, 6 years it's bee almost done! I can get some images from my scope... ...if interested let me know.
My new design is mid stream, so no schematics yet. (Soon, I hope). Right not I'm focusing on phase and linearity while trying to keep the thing stable. Phase shift is around -3.5 degrees at 20Khz. (-15 deg at 100Khz) I was shooting for less than 1 degree at 20k, but that's getting difficult. Even now it's just slightly under damped.
Response at small signals is from DC to around 300Khz, dropping to 100Khz at 40W (RMS) output. 70W at 50Khz, and so on. (I consider the limit of maximum power at the point where I can start to see distortion on the scope) It'll push a few hundred watts at 20Khz, but only for short bursts (small load/heatsinks)
I really need a %THD meter, and way to measure noise levels! (Any good recomendations?)
As for the Integrator, been tossing the idea around. Just trying to think of a few places to integrate it into circuit, where it'll be unobtrusive. I may 'borrow' some of your circuit for that. :)
-Dan
halojoy
traderbam - dear friend
I like you more than most of these "yes-sayers"
you make me think
you keep me alert
traderbam
In other words
I like you very much
So much that one day I might build me a traderbam amplifier
remember?
I do
halojoy
of sweden and jesus
*this is a transcription of a post of mine
in thread "greening a classic"
where traderbam has made a lot of nice thinking
carlmart
Remco,
Can you e-mail me?
I would like to know some more about those other designs you built and your findings.
Carlos
Rambi
I'm always interested!
I only have simulations for phase shift etc. With component values as shown it's about 10 degrees at 20kHz.
(IIRC that is. I'm in the middle of installing my new computer. Once I have everything back on-line I'll see if I can post an updated schematic with some of the suggestions integrated).
It's not mine; as I said in my first post most of it is bits and pieces from various designs (mostly Elektor stuff). The Crescendo Millenium Edition uses an integrator like this. After some searching I found that the 'Power Amp' (also Elektor) uses a variation with an integrator connected to the 'other' sides of the LTPs.
Remco
halojoy
It is yours.
We all have learnt from other & eachother.
That's human culture.
I have studied every single Elektor amplifier in its details.
I have almost complete collection from 1985 of Swedish elektor.
A good way of learning Electronics - not only for Audio.
halojoy, traderbam, Nelson Pass, peranders or AKSA
we all use what was brought to us by culture.
But then we add a touch of ourselves.
Our own contribution to the sum of human culture.
And so do you, my friend Rambi
Enjoy yourself - You are great!
/halojoy the great
dkemppai
Cool, here are a few images. (I hope you can find that camera to snap a few to post also ) :)
The measurements are pretty self explanatory, as to frequency, phase, and gain (can be calculated from peak to peak) Blue trace is output signal into 8 ohm 100W non inductive resistor. Yellow trace is input into amplifier.
I was going to grab a few more, but I left it run at high power a little too long... ...POP! SNAP! followed by orange flame from the fets, and lots of magic smoke. So, until I rebuild (In about an hour) you'll have to settle for the 100Khz and single 10Khz traces...
Also, the amp was running at +- 50 Volt rails, +- 70 volts seems to improve linearity at high frequencies.
-Dan
(EDIT Typos!)
dkemppai
Here's some sine waves, 100Khz.
Notice the distortion starting to appear on the rising edge. This is apparently due to the limited rising slew rate of the amplifier.
-Dan
Rambi
Hi all,
Thanks for all the helpfull comments and suggestions so far!
I thought I'd let you know what I'll do with them:
My plan is to first *finish* an amplifier (casing and all I mean), so I'll integrate the suggestions that are easiest to incorporate first:
- Lower value for R56 (100 instead of 1200)
- base resistors for Q9/Q109
- BC550C/BC560C in LTPs (to be honest: schematic is inaccurate since I already used those. The reason I put a cascode in the LTP in the first place was the slightly over 40V power supply, a little bit too close for comfort to the limits of the BC550 & BC560...)
I don't need alterations around ccs LED and cascode zener for reasons of reducing hum, that's already non-existent anyway ('pre-stage' and 'power-stage' are already somewhat decoupled by a LPF of R40/C42, R42/C43), so I'll leave those suggestions for v2.0
I already tried the lower R56 value (very easy modification of course) and was pleasantly surprised by the effect :)
Much more detailed! Switch from OpAmp based to solid state yielded much more details in mid & high. This simple change resulted in even more details but predominantly in 'lower' regions, e.g. cello and the lower keys of the piano ('better defined attacks of strings' is the best way I can think of to describe it). Some recordings are also less 'harsh' than before.
For the exisiting prototype the addition of base resistors for Q9/Q109 can be retrofitted relatively easy by cutting two tracks and drilling four holes. Since a decent amplifier needs two channels (either in the same case or separate, but I don't want to start that discussion here ;)) it's very easy to include it in a new PCB as well (minor mod).
All other suggestions require (and certainly deserve!) more investigation & design.
So why finish an amplifier first? Well, I don't expect to ever finish with tweaks and improvements and it would be a shame if that would prevent me from ever finishing a complete amplifier.
Also my ultimate goal is a bi-amped system, actively if possible, but that's in a far and distant future. Since that implies a second amplifier I already have a valid excuse to look into & try the other suggestions :D.
Which brings me to the final (last but certainly not least) reason: The SWMBO factor (or HWMBO in my case). At least finishing a complete amplifier is a very persuasive manner of justifying more time & money spent on this subject ("What? are you telling me that you don't want to enjoy better music?" :D)
Next steps:
- build the other channel.
- put it in a nice 19" case (hmm, that makes it sound so easy)
- try not to forget to take pictures along the way
- enjoy/work on v2.0/think of preamp (all at the same time)
Wow, what a hobby!
Remco
P.S.: Sorry for the long post, but I feel that the thoughtful and helpful suggestions at least deserve some explanation as to what I'll do with them.
Rambi
I'll stick to about 40V... Never let the magic smoke escape!, you should know better than that :D
Nice pictures!
Cool to see the phase shift increase between 10 & 100 kHz .
(and the 'wobbles' on the peaks of the triangle @100kHz)
If I manage to get my hands on a digital camera you'll see 'real' scope pictures (including the 'Tektronix 434 storage oscilloscope' I mean ;)).
Were you already able to listen to it and find out how it sounds?
(Just curious, since you apparently use fets)
timc
Hi Rambi,
Is there a slight error in the DC Servo?
Shouldn’t the centre point of the zenders be connected to ground and +ve input of opamp instead of the –ve input.
Tim
dkemppai
This is the second set of Fets I've burned up, so there's lots of magic smoke on the walls to help me think :)
(Still can't figure out why my wife bought me that fire extinguisher, fets ALWAYS self extinguish :) Trust me, I know)
Yes, I use fets for the output devices, but the rest of the amp is BJT. No, I have not had a chance to listen to it. Before I hook speakers to it the bias voltage for the output fets needs some temp compensation. It also needs the integrator (Although, the trim resistor I'm using for DC offset seems to work well). I've only spent a few days doing the design/test, so there's lots that needs to be done. I've got my first amp sitting here also, and I plan to do some 'side by side' comparisons.
You say you've got a board designed? How much for parts for your amp? Are they avaliable from common supplers in the US? It would be nice to hear how yours sounds. It would also be nice to see some pics of your board and stuff, as you get them!
Also, Looking at your schematic (Nice layout), You may try a resistor from base to emitter on both Q9 and Q109. Something in the range of 470 to 100 Ohms. Darlington pairs often use them to help with the slew rate...
-Dan
grimberg
dkemppai,
What is the brand and model of the oscilloscope you are using? I'm currently shopping for one.
Rambi
quote:
Originally posted by timc
Hi Rambi,
Tim
I don't think so, the diodes (not zeners) are just there to prevent the input from rising above or below the supply voltages of the opamp (not very likely, but you never know).
Since the integrator is connected to the input side of the LTPs it needs to be a 'negative' integrator as well (i.e. positive input voltage causes negative going ramp on output of integrator).
Besides, connecting it the wrong way around would cause a DC offset, not cancel it, that would be noticeable soon enough ;)
Remco
Rambi
Most stuff is 'ordinary' and shouldn't be hard to get in the US. Don't know about the BC type transistors, should be no problem to replace them with other types of small signal transistors and maybe MJE340/350 for the BD139/140 types?
Sanken transistors are the most expensive parts (for populating the board, i.e. not counting heatsinks, casing, toroids, etc.)
BD911/BD912 (which I use for prototypes) are a few euros per piece if I buy them in a store, but on-line store like Reichelt seems to have them for about 50 eurocents (roughly the same in dollars).
Remco
dkemppai
quote:
Originally posted by grimberg
dkemppai,
http://www.tek.com/cgi-bin/wtx.cgi?...FrameSet=Escope
A bit spendy, but nice! I've also used the TDS1000, TDS2000 and TDS200, and TDS400 series. All very nice. (TDS1000 Starts at about $1000)
-Dan
Jeff R
I have a question about the servo op amp, U1. There is only a capacitor in the feedback loop. If the op amp has a dc output offset voltage (and they all do) it is possible for a dc voltage to develop across the integration capacitor and ultimately build up so large as to saturate the op amp. Typically, a large value resistor is paralled across the capacitor to provide a path for the dc to discharge. You have a pretty large Rin right now, and the LF411 is not exactly a low offset voltage op amp, so I am concerned about this charge buildup.
If this is a problem, you may need to lower R80 to maybe around a 10 - 100K and parallel C80 with 1 to 10 M. The output network may have to be rescaled as well.
peranders
Very dangerous to drive the amp at very high frequency with no or little load, even dangerous with load. I have made the same mistake myself. +-47 V, BD317, BD318. No load, 200 kHz = smoke! The output transistors started to conduct at the same time. Talk about fireworks in the fuses!
dkemppai
quote:
Not really true. I've been running the amp at HF for a couple of days now, load and no load. As long as voltages do not go over specified ratings of parts, no harm is done. Under certian situations, the lead inductance can generate large voltage spikes, but I hardly suspect this was the problem at 100Khz.
In my case, the problem was not the frequency, but rather the heat generated. I was dumping about 70W into an 8 ohm load for an extended period of time with poor heatsinking. I knew heat was a problem, so kept high power tests to short bursts. (All, but the last one, of course)
-Dan
P.Lacombe
Operating an audio amplifier at high frequency and max power for long periods can result in destruction of the output transistors.
This is caused by cross conduction of output transistors, because of the relatively long time needed to evacuate charge carriers in the base-emitter region.
Amplifiers with modified output drive like this one (R56, C51) are more tolerant, because of the accelerated evacuation of the charge carriers by the RC network. This is also depending on particular characteristics of the output transistors, high Ft and low Ccb are essential.
Regards, Pierre Lacombe.
dkemppai
I realize that cross conduction can be a problem, but I'm pretty sure that this is not so in my particular case. The output devices get just as hot at 1Khz as 100Khz. under similar loads. (Again because of the small temporary heatsink). Under no load situations HF and LF the devices stay cool.
However, I guess, if you consider that the fets may need more VGS to conduct current into the load than under no load, there is more charge in the gate, and thus more to remove. Not sure how more current affects the levels of gate charge with the input/output capacitance.
I would suspect that with the gate charge and input/output capacitance, the problem should also be as apparent on the rising egde of the waveform as well as the falling one, showing itself as a limiting of rising as well as falling slew rate.
Overall, my gut feeling is this isn't the case, but I'm open to the suggestion. (And more comments)
-Dan
Rambi
quote:
In this case that won't matter since the (inverting) integrator feeds back to the input of the amplifier; It's a closed loop. A dc buildup by the integrator will be amplified (by the amplifier) and fed back to the input of the integrator, negating the buildup (since the integrator itself is inverting).
Of course an offset of the opamp might cause the output of the amplifier to be not exactly 0V. But I'm not interested in 'absolute zero', I just want to compensate for drift by temperature changes and imbalances in the circuit (although it probably won't compensate for totally unmatched components).
Although there's no connection drawn in the schematic, it is connected by the label 'IN', which is also placed at the top of C61. I used labels here to keep the schematic relatively clean. Same holds for the feedback (NFB labels, between R54 & R55 and at the base of Q4).
Remco
Jeff R
Remco
While true, the general rule in audio design seems be to use local feedback rather than overall global feedback. By using a paralleled resistor you can negate most of the charge build up right there without having to go through the feedback. I have no idea if the effects are audible - probably not - but then who would have thought that different brands of metal film resistors would sound different?
Just something to consider. Good luck!
Rambi
.. I have no idea if the effects are audible - probably not - but then who would have thought that different brands of metal film resistors would sound different?
Thanks!
And yet another option to include on v2.0 :)
:xmasman:
Remco
Page generated in 0.14369893074036 seconds with 17 queries,
spending 0.01013851 doing MySQL queries and 0.13356042 doing PHP things.
Copyright ©1999-2009 diyAudio.com
