diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Need service manual of Sony CDP 338ESD - Click HERE for Original Thread
beauty_divine
Please help me finding it, if available.
Many thanks for help!
beauty_divine
So far I'm not the luckiest man in this forum - since my registering I've started two threads asking for help and no answer ever arised:xeye:
Do I ask wrong things?;)
saifee69
What is the problem with your 338esd, i can help you as i am using the same player.
beauty_divine
quote:
Actually there is no problem - I bought the machine with the intention to mod it. That is why I'd need the service data and detailed schematics.
I'd be grateful if you could hand it over.
beauty_divine
... seems better leave any hope for help ... :xeye:
rabbitz
You can get it at Manuals Center but you have to pay.
kevin-g
I'm a new member, joined today and cruising threads. I once owned a 338 [a £600 player back in '89 in the UK]. I have somewhere a manual for this and I also modded the outputs with better opamps and output caps. From memory they used NJM5532's and a 4560 for the headphone circuit. For the life of me I can't remember what I used to swop out, possibly AD712's or OPA2604's but this was the very early 90's.
It modded well and was well built with good power supplies. If I was modding it now, all I'd do is swop out the mains diodes for shottky/ultrafast versions and change the opamps and perhaps the output caps. One could fit a Trichord clock to it, it responded well according to their database, but this is a 1989 machine and the laser must be on its last legs by now....
I have had a house move and stuff is in two locations. If you still need the info, I think I could scan those relevant sections if you contact me.
Kevin
zanash
don't forget the muting transistor[ if fitted ] these have a very detrimental effect on the sound.
beauty_divine
quote:
As it is a top class machine it doesn't have muting transistors, but relay.
The output opamps I'm going to replace with AD 8066.
The output caps are totally not needed - there is a little voltage offset remaining and it is easy to get rid of it.
I also exchange the transformer secondary part windings supplying the analog part with a toroid and primary stabilized voltage before the original stabilizer schematics.
I really need the service manual in case something might go wrong.
zanash
replacing the rca sockets and hard wiring with silver will also provide a useful step up in performance ...as long as you get good rca sockets
kevin-g
Yep, agree with above suggestions. The good thing about the 338 is that there is space to do mods if memory serves me right.
It would probably make a good transport if Trichord clocked. I'm trying to remember as manual not in this location, if it was this generation or the previous 337 gen that used Phillips processing chips. Ken Ishiwata of Marantz swears that the Phillips dig. output chip was the best ever made by anybody [this quote circa 2004 ish].
K
beauty_divine
So far so good with mod suggestions ... but the schematics is still missing. Verbal exercises are only good when accompanied with real results ;)
es44
pssst, here you are ;) :
cdp-338esd
Have fun with it.
Best regards
Ebbe
beauty_divine
quote:
cdp-338esd
Have fun with it.
Best regards
Ebbe
Thanks a lot my dear friend!
It is all I needed.
Best to you too!
Ivo
es44
You are very welcome. I just hope you succeed.
I don't think people should pay for this kind of stuff. too many guys make i living out of selling manuals that's downloaded from the internet anyway.
( Not to mention that most of them are copyright );)
ps. If you frequently is in need of service-manuals, then you can register at www.sharefx.com, it's free
Best regards
Ebbe
beauty_divine
Hi Ebbe!
Now I need the service manual for CDP-228ESD by Sony but the website you mentioned does not respond :-(
Could you please help me finding this model schematics?
es44
Sorry, that one is not in my list here :cannotbe:
The best thing to do is to hang on to Sharefx, and make request from time to time.
Eventually it will be there.
Good luck
Ebbe
beauty_divine
Good luck
Ebbe
I tried many times with Sharefx but it does not work. Do you know why is this and will it be fixed?
es44
quote:
It's got some up's and down's, but right now it's up :)
I usually try from time to time, and mostly i'm lucky after a few hours.
Ebbe
Page generated in 0.042525053024292 seconds with 17 queries,
spending 0.00805879 doing MySQL queries and 0.03446627 doing PHP things.
