diyAudio.com diyAudio Forums Archive > Top > Source > Digital
HELP - how to upgrade clock in rotel 855 CD - Click HERE for Original Thread
fatgaz
I hope to tweak my rotel rcd 855 by putting in a tent labs xo3 clock.
BUT I can't work out the clock circuit. I don't have a schematic yet. if anyone has that section of the digital circuit ? also the power supply section would be nice for further tweaks.
supposedly I should be able to find a cap crystal and resistor in parallel via two caps. I cant see any caps near the crystal !
also where is the best place to tap the spdif signal for reclocking ? The xo3 pcb has a recolcking section for providing a new spdif output for external dacs.
this cd is a classic philips unit cdm4 with tda1541a saa7220p/b.
hope someone can help !
Gareth.
Guido Tent
Gareth.
Hi
The caps may be on the other side of the PCB. Info on the SPDIF output of the SAA7220 can be found on my site:
http://www.tentlabs.com/Products/cd...O23mounting.pdf
best
Fin
Go one step further and convert the OX3 to an OX3.5 - then clock the TDA1541A directly from the new clock. Also, clock the decoder directly from the new clock.
Page generated in 0.032975912094116 seconds with 17 queries,
spending 0.00904989 doing MySQL queries and 0.02392602 doing PHP things.
