diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Can someone help a noob?? - Click HERE for Original Thread
sts9fan
I really could use help wiring my ausiosector kit. the manuel is not really doing it for me after I assembled the boards. The Transformer I have has two sets of red-black for the 120 input and two sets of green-blue for the output.
bushroot
Is the tranny dual primary and dual secondary? Most that I've used have 3 wires on the primary side for 240 or 120v operation and 2 sets of output wires. To check if yours is a dual primary, use an ohm meter and check the resistance of the primaries first. If it's a dual primary, there will only be an electrical connection between one pair. This should be one of the black and one of the red. Then check the other pair and you should see the same result. Then check your secondaries and see which ones are paired. Finally, power one of the primaries and see which secondary corresponds with it. I usually label them. It's not that it matters much which side corresponds to which unless you're fusing each side seperately at the mains, but it's nice to know. If you do have a transformer with both dual primaries and secondaries, it's electrically the same as having 2 seperate transformers. You can run them in parallel or series to achieve the voltage you're looking for. First things first though. Get out the meter and find out what kind of animal it is.
AndrewT
and use a bulb in series with the primary to stop you blowing it up!
I use a mains bulb (various wattages from 40W to 150W) whenever I start up a new project or have carried out maintenance or modified a project, just in case I have mis-wired something.
I keep a plug top with socket outlet and bulb holder permanently wired up. It gets used regularly.
I read about it here, this is a damn good Forum.
sts9fan
Thanks for the help guys I am well on my way thanks to the helpful people on this board!
BrianDonegan
Trafo sounds like an Antek (ebay). If so, here you go...
sts9fan
yeah thanks for that I am the one you emailed that too earlier this week.
flraer
I'm sorry for stealing this thred but I just wonder if someone got a picture the the one you uploaded brian but for the LM 4780 kit instead?
It would be really nice if someone could help me.
BrianDonegan
I'll try to do it tonight...
flraer
Thank you Brian :)
This is a very good forum with very helpful users!
Page generated in 0.026882886886597 seconds with 16 queries,
spending 0.00989223 doing MySQL queries and 0.01699066 doing PHP things.
