diyAudio.com diyAudio Forums Archive > Top > Source > Digital
One sample delay between channels - Click HERE for Original Thread
percy
For stereo digital data the series of samples contain alternating channel information - i.e. L,R,L,R,...L,R.... One channel is always following the other. And thats how its fed the DAC as well. So when the DAC ouputs analog signal for both L and R channels is it simultaneous or is it still lagging in the analog domain as well ? Does the DAC compensate for that delay ?
I'd like to extend this question to Analog-to-Digital conversion also. Is there only one ADC that alternates to sample each channel ? or two ADCs (one per channel) that sample simultaneously ?
rfbrw
Sampling and conversion are simultaneous
percy
ok that takes care of the A->D part.
but what's the deal with the channel delay in the DAC ?
For now all I want to know is if ALL well regarded dac chips out there exhibit this 'delay' and something needs to be taken care of as part of the big picture of the whole DAC design ? or is it something that the DAC chip generally takes care of already ?
(is there a definite term for this ? what's it called ? I tried searching the forum and all I could find was one really old (and hijacked) thread where the discussion trailed into this delay but didnt really help).
rfbrw
There is no delay. Sampling (A to D) and conversion (D to A) are simultaneous
percy
so the dac holds the first channel data until the second channel data becomes available and then converts both simultaneously ?
sorry for my novice questions. When it comes to digital audio I am!
rfbrw
Something like that.
percy
while you were responding to my post I found this
Apparently they would need a "workaround".
Interestingly they dont have a similar errata for the new chips(CS4270/71/72).
rfbrw
They aren't typical of the breed and are at least 5 years out of date. Besides from the POV of a standard serial datastream, the delay is half a sample not one.
Page generated in 0.027956008911133 seconds with 17 queries,
spending 0.00808930 doing MySQL queries and 0.01986670 doing PHP things.
Please support our sponsor.
