diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Looking for a tutorial? - Click HERE for Original Thread
Carcano
Hi experts! Extreme noob Carcano here with my first post!
Im a guitar player, and want to build a low-watt power chip amp based on the LM380. I have the chip already, along with a Jensen 8ohm 8" speaker and a 12 volt power supply - thats it so far.
Of course I haven't got a clue what I'm doing, except I'm good with a soldering iron, and am willing to spend whatever time and money is necessary to build what I have in mind...if its possible???
I dont even know if the LM380 will distort. What would be ideal is to get a good clean sound up to 'loud talking' volumes, and then have it gradually distort into the 'shouting' range...4 watts max. Even better if it ONLY distorted in the higher freqs, as this would give it a more spongy feel like power tube distortion.
What I need right now is to study a 'how to' web resource on simple circuit building. Can anyone here direct me to such a site...links???
Thanks so much!
Carcano
Heres a simple LM380 circuit I found rummageing around in the archives.
Would this work as a low-watt guitar amp? The input from an electric guitar is anywhere from zero to one volt, and I dont know if this is enough to power an amp like this into distortion. I dont want to include a volume or tone control in the circuit as I already have this on the guitar.
davidallancole
Where do you get the 1 Volt from. Guitar pickups are usually much lower. You mite need a gain stage before.
ppfred
quote:
Thanks so much!
Lots of good tips & howto info for beginners on this one
http://www.bcae1.com/
A gainclone build on perforated board:
http://www.werple.net.au/~gnb/audio...0designlog.html
You'll find lots of info on cct building on these sites:
http://gainclone.com/phpBB2/index.php
http://c.webring.com/hub?ring=gaincloneamplifi
http://www.geocities.com/rjm003.geo...dio/diy_gc.html
http://myweb.tiscali.co.uk/nuukspot/decdun/
http://www.adx.co.nz/techinfo/audio/gainclone1.htm
http://jwg.student.utwente.nl/fedde/chill-amp2.html
fred p
Carcano
You could be right. Im just guessing because I sometimes use three overwound pickups in combination.
Why would I need a gain stage?
Carcano
How do I determine whether a chip needs a gain stage from the spec sheets?
Carcano
Excellent Fred!
I'll dig into that...thanks!
Page generated in 0.02916693687439 seconds with 17 queries,
spending 0.00910044 doing MySQL queries and 0.02006650 doing PHP things.
