diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Good 5 volt opamp? - Click HERE for Original Thread
LukasLouw
Can anyone reccommend a good unit gain stable dual opamp running off a single +5v supply to run a CS5341 analog to digital converter?
The ADC's input impedance is 25K, and needs 1Vrms, or 2.8Vp-p for full scale output.
Thanks,
Lukas
peufeu
What is the input capacitance of the ADC ?
(is. is it a sigma-delta or a sample and hold ?)
LukasLouw
Delta-sigma type.
Interestingly enough, input capacitance isn't specified, or at least I can't find it on the datasheet. However, teh DO reccommend 2700 pF from each analog input to gound.
Lukas
peufeu
OK. I asked because sample&hold ADCs, well, sample and hold the signal, which means they store it in a capacitor, and if the input opamp can't handle it, you have a problem.
Apart from that, I have no idea, but I'd suggest looking at the opamps used by people to power portable headphone gear at head-fi.com
jackinnj
Take a look at the OPA365 from Texas Instruments.
Page generated in 0.019675016403198 seconds with 17 queries,
spending 0.00800610 doing MySQL queries and 0.01166892 doing PHP things.
