diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
My first DIY project based on tripath - Dyparadise CHARLIZE - Click HERE for Original Thread
fosforo
Hi to all,
I am italian and i am very interesting in DIY project. :D
I would like to ask you some questions and evenctually some best practices for building my first project based on CHARLIZE from DIYPARADISE.COM.
Please, try to understand my bad english. :rolleyes:
I bought the kit because i was very curious about Tripath and having to sonorize a small home studio i thinked that it was a good solution.
Googling around and also inside the forum i found some good review of the kit.
This is the setup
PSU switching Skynet 8080
CAPS Nichicon 10000 Uf/63 Volt
Charlize with air core inductors
Alps Blu 50K
Golden RCA connectors
Golden speakers connectors
OFC calble for connecting CHARLIZE -> SPEAKERS CONNECTORS
CAT 7 Cable for connecting RCA - ALPS - CHARLIZE
Solder with high percentage of silver
HIFI2000 Enclosure
Charlize will play a chain based on:
.CD Marantz CD63-MkII KI
.Indiana Line 4.30
.Signal Cable YANXING OIL INJECTED (Attached you will find a photo of this strange cable)
.Speaker Cable TNT-Star
I would like to have your opinions on such type of configuration and on the components selected.
I have a doubt about AC Line filter: Is it right to use it or not?
If yes, why?
Thank you very much for every reply
Bye
Fabio
ichiban
You will get more responses if you post this in
the "Class D" Forum. :rolleyes:
diyAudio Forums diyAudio Forums > Top >Amplifiers >Class D
anatech
Hi Fabio,
I moved your post to the Class D amp section for you ...
-Chris
v-bro
I think you won't be disappointed, not to say there are better options...:p
The AC line filter smooths out any possible interference on the 50hz AC power on the net, use it if not only to improve the audio than it might save your equipment. I don't think it will be very necessary...
Some people are not so enthusistic about the Charlize too:
http://www.diyaudio.com/forums/show...&threadid=91678
dabeat
Any1 know the Newclassd ?
Can i have some informations ?
Page generated in 0.025078058242798 seconds with 17 queries,
spending 0.01060796 doing MySQL queries and 0.01447010 doing PHP things.
Please support our sponsor.
