| Narcisse91 |
Is anybody here using ferrite beads on internal wires in their amplifiers? A search looked like some people were, but not too much mention of them from what I saw.
As I was shopping around, figured I would see what people had had good and bad experiences with.
Also, my experience is more with generators operating at much higher frequencies, but I'm new to DIY audio, so maybe something like this isn't needed at all at these power levels and frequencies.
Anybody with any suggestions or experiences, please share them.
Thanks |
| dhaen |
Even with 4 or 5 turns, the thing is only suitable as a UHF RF choke.
At very low impedance nodes, the reactance becomes significant at low-megahertz.
I can't think of any true audio applications.:scratch: |
| Narcisse91 |
| quote: | Originally posted by dhaen
Ferrite beads don't have turns. They're simply cores of ferrite that a wire runs through. The purpose is to act as an EMI filter. This same idea would apply, but only if a filter like this was needed. I don't know if its needed or not. |
| dhaen |
| quote: | | Ferrite beads don't have turns | They can.;) They are used in UHF circuits with very thin wire as RF chokes.
I admit they are more usually used with a single (thick) wire running through them. |
| Narcisse91 |
That would be a ferrite core :cool: and is basically a toroid.
I like word games :)
| dhaen |
| quote: | | That would be a ferrite core and is basically a toroid. | Absolutely. ;)
But then again, a conventional "bead" is merely a torroid with half a turn;)
I like word games too:cool:
Basically what I was saying was that there isn't a node with low enough impedance for an impact within the audio spectrum.
As far as RFI is concerned, they're of little use at the input, because the impedance is high.
At the output it just might be another matter. They could be good at stopping >1 or 2GHz fom entering the feedback loop from your speaker wires:) , but as has been pointed out before, Zobel networks normally stop that.
Cheers, |
| Narcisse91 |
Absolutely. ;)
Cheers, |
Typically, I'm used to using them on wires between driver circuits or current sense circuits and PAs, on the high power wires. Depending on how an amp is built, this could be more than just the output wires. but I guess it would vary depending on the type of amp and construction.
Although you could throw them on the input to reject anything picked up on the interconnect coming from the source, I didn't think that noise would be a problem, like you said as well.
As far as I can tell, you would need a feedback loop without a filter for this already. With no feedback, or with a good filter on the feedback, it wouldn't do much. But that's what I don't now, since I'm new to frequencies this low. |
| yves |
Ferrite beads or cores are lossy at high frequencies (hundreds
of khz or MHz), they are therefore very good isolation
devices to prevent rf from entering a circuit via power supply
lines, and to prevent rf from the circuit to pollute other circuits
connected to the same supply as the circuit itself.
The great thing about ferrites is that they are lossy, and
it absorbs rf energy and coverts it to heat. This way, none of
it gets anywhere. Inductors and capacitors merely move
rf energy around, either preventing them from entering
a particular circuit or bypassing it to ground. This is not
neccessarily the best solution for emi as this unwanted
rf energy still needs to be directed to a clean ground.
Ferrite beads are very useful in digital audio circuits, as they
operate with square waves, and hence, very large amplitude
harmonics at tens of MHz. If you put a scope probe at the
power supply of your cdp filter and dac chips, you may see
square waves riding on it. This can, and usually will,
contaminate the other power supply lines connected to it.
A ferrite removes all this cleanly.
Even in low frequency circuits such as amplifiers, rf energy
can enter the circuits via the power supply cord. And if these
are large enough, they would cause intermodulation distortion
in the amplifier by modulating the powe supplies. So ferrites
are also useful, but you need really high current ferrites for
these.
Hope this helps,
Yv |
| Bobken |
Beware of using ferrites on a power amp's output, as the well-respected UK audio designer John Linsley Hood has said that this can (will?) cause severe unwanted distortion in some cases.
From memory, I seem to recall that this is due to some hysteresis effects in the ferrite, itself.
I will try to find the reference to this caveat in my 'library' of books/articles, and will refer to the text in more detail, when I have come accross it.
Of course, using the much smaller values of inductance like 10uH made up of a few turns of wire (often wound around the body of a 10 Ohm, or so damping resistor), as is frequently used in power amps at their outputs, is a different matter.
This kind of wire-wound inductance seems to upset the HF square waves somewhat with some damped ringing, though, but does assist with stability if unusual speaker loads are contemplated.
Regards, |
| dhaen |
I have great respect for JLH.
In the late 60's I built his class A SS amp, and uprated it for 50w(per channel). Something for a class A!
It became the party amplifier "supreme", and was often to be found with it's remote heatsink in the kitchen sink, with cold water running over it. :cool: |
| Circlotron |
But then again, a conventional "bead" is merely a toroid with half a turn;) | Not trying to be picky or anything, but a toroid never has less than one turn. The remainder of the turn will be made by the return path of the signal and so may be some appreciable distance from the core, but nevertheless is part of that 1 turn. |
| dhaen |
| Ya got me there:blush: |
| chris ma |
One time I was in a surplus store I bought a couple dozen of various size ferrite core for approx. a dollar a piece. I just used them all up with all my electronic gears. I only use them on the power leads(AC and DC) going into gears, TV, VCR, DVD player, A/V reciever, active subwoofers, DAC, power amps, and even at the leads of the power bars/extension. Just find ways to use them all up.
The way I used them is to feed thru the core two to three times especially the 3inches diameter cores because the plug can pass thru the core easily. For the smaller ones the lead can just pass thru once; since all my computers, laptops etc all their leads have the ferrite on them, and they were cheap, just use them to be sure. Whether they work or not I do not know, but they are all out of sight out of mind. I am sure they must have some effects on my system, or preventive measures so to speak?
Chris |
