| Gcollier |
After taking a look at the new LM4562 from National I was mighty impressed by it's specs. I decided to design a board around it using the WM8816 from Wolfson to control the gain. I figure this is the next best thing to a stepped attenuator, but this also has the advantage of having a fixed input impedance.
The design itself is pretty basic. A PIC16F88 (love this chip) will be used to control the WM8816, which sets the gain of the LM4562. I have added headers for ICSP, auxiliary control of the WM8816, and the individual PIC ports for the connection of buttons, an IR Reciever, or an LCD etc. I still need to program the software for the PIC, so I will be working on that for the next little while.
What I am most interested in right now are some ways I can improve the design. If you have any constructive suggestions please fire away.
G. :) |
| Gcollier |
| Here is the board. |
| Gcollier |
| A 3D View of the Board :D |
| Carl_Huff |
| I've been looking to grow my PIC programming skills. The 16F88 looks like a great place to start. Can you recommend a good 'C' compiler and development system? |
| Gcollier |
| quote: | Originally posted by Carl_Huff
Actually, I don't use C myself. I have been using Picbasic and Mikrobasic. You could take a look at this product http://www.mikroe.com/en/compilers/mikroc/pic/ if you are set on using C.
The PIC16F88 is indeed a very nice chip. It has nearly every feature you could ask for (well except USB...) and is in a nice sized package. The internal oscillator is a nice feature and also frees up two more pins for I/O options. I am by no means an expert at PIC programming, but I am competent enough to handle simple things like SPI. For programming my PIC I built this unit http://feng3.cool.ne.jp/en/pg5v2.html which I use with WinPIC. I also have a little JDM programmer with an ICSP header on it, you can find the details for that one here http://www.belza.cz/digital/jdm.htm.
G. |
| Russ White |
Man that is some good stuff mate. :)
Good work, and thanks for sharing!
I have a very very similar circuit for the same Wolfson chip, but with the PIC16F690(or its brothers) and AD8610.
I currently experimenting with the 8816 in a pretty unconventional way... (think symmetry)
BTW the LM4562 is just plain awesome. I just can't believe how good it is for the price it will be sold at.
Cheers!
Russ |
| Gcollier |
| quote: | Originally posted by Russ White
Cheers!
Russ |
Russ,
Thanks for the comments! You have me curious now! What are you doing with the 8816. Are you using it with a balanced circuit like the THS4130? :)
I may still make some minor changes to the PCB. I already added a 220nF decoupling cap for the digital supply on the WM8816. I may also change the hee supply and have a seperate one for the WM8816 and the opamp. I can likely do this with some additional jumpers.
G. |
| Russ White |
| quote: | Originally posted by Gcollier
Russ,
G. |
Oh your welcome, I am happy to say you have been one I have learned a lot from around here. :yes: So thanks right back at ya!
Well yes, but not in a way you might expect. The THS4131 is CFB which I am sure you realize complicates things a bit. I don't use it conventionally with the 8816, but... in the global feedback of a super symmetrical power amp for a integrated amp (TXO). It does work(and very well), however I am torn between this chip and a more "discrete" approach. So far I would have no qualms using the wolfson chip.
Cheers!
Russ |
| jaycee |
| Sorry to butt in with an unrelated question, but what's the program that you used to generate the 3D view from the EAGLE board? |
| Gcollier |
| quote: | Originally posted by jaycee
No problem, I used the Eagle3D ULP available here http://www.matwei.de/
Eagle3D generates a .POV that you can use with POVRay, a freeware raytrace program, to generate the images. The ULP is not entirely user friendly unless you stick to very specific libraries, but once you get the hang of it it is pretty easy. Also there is a tutorial here http://felixchenier.homelinux.com/E...rttutorial.html that shows you how to make you own parts.
On another note, I need to change the input cap, or remove it completely. It seems that the low end rolloff created by the RC filter on the input of the WM8816 is way to high (~48Hz). I think that I will just remove it entirely. This should also allow me to get another decoupling cap closer to the analog supply pin of the WM8816.
G. |
| turbolx5oh |
| A bit off subject but Gcollier, I've been thinking about a PIC basic complier for a while now. If you had to buy one would it be the mikroBasic or the PICBasic? |
| Gcollier |
| quote: | Originally posted by turbolx5oh
Picbasic PRO, only because it has been around longer and has most of the bugs worked out. Mikrobasic looks to be catching up fast though, and is certainly nicer looking. Also because it has been around so long Picbasic is easier to find support info for on the web. If you have the option get Microcode Studio Plus along with Picbasic. Again I am no expert this is just what has worked for me. If anyone else has good suggestions please chime in! :D
G. |
| Gcollier |
I have attached a picture of the updated board layout. Basically I removed the input caps on the WM8816, changed the SPI pinout from the PIC and added headers for the controls, ICSP/ICD, and the remaining pic ports. I also added a protection diode to keep the 13V programming voltage out of the WM8816 if you are using ICSP to reprogram the pic. I also altered the power supply routing a bit. With the new layout I can easily remove the microcontroller section of the board and use a single controller to operate multiple preamp boards in a multichannel setup.
I plan on etching this desing tonight, and will likely assemble it tomorrow...I think I have all the necessary parts...:xeye:
G. |
| Gcollier |
Well here is the actual board hot off the soldering iron. All that is left to do is hook up the input and output wiring and connect some sort of control buttons or pot...oh and finish the code for the PIC. :D
Too bad I will be away this weekend, I'll have to wait until Monday to finish it up :(
G. |
| Russ White |
Cool!
Looks great! Can't wait to read that it works! And, I know it will. :) |
| jleaman |
| Im interested to know how it sounds when all complete :D |
| Gcollier |
| quote: | Originally posted by jleaman
I hope it doesn't "sound" at all ;)
I'll be sure to let you know if it is any good.
G |
| MikeBarton |
Hi
I like your design/idea & thought I would have a go along similar lines.
In trying to design the board, I noticed that there may be a problem with your schematic (& hence the board itself) inthat according to the datasheet I have for LM4562, the V- supply is pin 4 and the V+ is pin 8.
Apologies if I am wrong on this as I'm a bit new around here......
I just wouldn't like you to waste a good ic :eek:
Mike |
| Gcollier |
Yup...I goofed when I drew the schematic. I mirrored the opamp symbol to get the - input at the top...but neglected to realize that the PSU connections also flipped. It made some lovely smoke when I switched it on, even chewed up 2 transistors and 3 resistors in my PSU :eek: Quite a stupid mistake if I do say so myself...fortunately I was testing it with an OPA2134 ;) Now to figure out how to get the smoke back in!
Not to worry though I reworked the layout with a few other changes. I just haven't had time to put it together. I removed the input caps, and also changed the supply routing to correct the original issue and also seperated the PIC/volume IC supply from the opamp supply. I also went for a star ground instead of a groundplane. I am going to run this from a much more simple regulated supply than the one I was using, especially given the excellent PSRR of the LM4562. I just need to find some time to put it all together.
G. |
| paulb |
| quote: | Originally posted by MikeBarton
... the V- supply is pin 4 and the V+ is pin 8.
| Right, you are. I'm guessing he hasn't powered it up yet. |
| Gcollier |
Well my conclusion from version 2 of this circut is that it sounds like $hit! Too bad really I was hoping this would work out well...oh well back to the drawing board. I toyed around a bit with the grounding and the supply, but just couldn't make it sound good. For reference I am using an OPA627/buf634 setup. This setup just didn't come close to that for me. It certainly isn't the opamp that is at fault as this one sounds great in some other implementations, even in a simple CMOY. I suspect that I am getting noise introduced from the PIC. I should have followed Vetrans idea of using an optocoupler.
| mlloyd1 |
too bad ...
i don't know the details of your implementation, so i'll ask my dum question anyway - does the sound improve if you put the micro to "sleep"?
mlloyd1 |
| I_Forgot |
It looks great, but all that effort and no Jung super-regulators to power the analog stuff?
If you have uC noise problems, put the uC to sleep when it isn't actively changing the volume. In sleep mode even the clock oscillator stops.
Add an LCD/OLED character display port, and a inputs for a rotary encoder and an IR receiver and you're there, dude!
I ran into this yesterday- it would be real nice to use one- programming should be simpler than LCDs because there's no waiting for the LCD busy flag to clear. OLED display 1
OLED display 2
I like PICs too!
I_F |
| Gcollier |
Actually it does have ports for an LCD display. I didn't bother to connect or code for it for experimentation purposes. It's a 20 X 4 backlit unit. I used buttons in this implementation but was actually planning on using a simple 10K pot read through the AD convertor and using that to adjust the volume. The PSU I used to feed this is actually quite good. It is a regulated supply followed by a discrete regulator. I included an LM7805 on the board for the necessary 5V for the WM8816 and the PIC.
I didn't actually put the controller in to sleep mode, I'll give it a try and see if it helps any.
G. |
| I_Forgot |
I have used a Grayhill 61C11 optical rotaty encoder that has a pushbutton at the end of the shaft. It's rated for 1M rotary cycles and 3M button cycles, so it will last almost forever.
It's very easy to use with a PIC. A simple lookup table tells which direction it is rotating so you can increment or decrement volume counters. It is easy to set up the circuit and code so that it will wake the pic up when the shaft is turned or the button is pushed.
With multiple lines on the display you can set up a balance adjustment mode as easily as volume control.
Here's a cool input device that is used in the Slimdevices Transporter:
http://www.immersion.com/industrial...ucts/PR1000.php
It is an encoder with software controlled, magnetic detents!
I_F |
