diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Amplifier Design Book - Click HERE for Original Thread
pixie
Does anyone know of any good books on amplifier design?
I have some books that show the basics, but nothing that will work in the real world.
Thanks,
pixie
blmn
Pixie,
You can try these:
Designing Power Amplifiers - stephen Kamichik - Simple and with some pratic;
Valve and Transistor Audio Amplifiers - John Linsley Hood - If you like tube sound;
Audio Power Transistor Design Handbook - Douglas Self - Very good book in my opinion;
High Power Audio Amplifier Design handbook - G. randy Slone - Very good book with projects and PCB pictures.
You can buy all of them at Amazon or Old Colony Lab Sound.
blmn
The real name of the 4th book is:
High Power Audio Amplifier Construction Manual
Sorry
promitheus
I agree the Audio Power Amplifier Design
Handbook from Douglas Self is one of the best.
ISBN 0-7506-2788-3
thespeakerguy
While not a specialized amplifier book, "The Art of Electronics" by Horowitz and Hill covers just about anything you need. Anyone working with these amplifiers should own a copy of this book. It will help you understand more about each of the circuits used in the amplifier, providing a good foundation for the specialized knowledge from the other books.
blmn
Thanks Promitheus,
I haven't realize until now that I changed the words on Self's Book.
Sorry
glodanr
Can anyone help me with with some online documentation on how to build an stereo amplifier (4X100w or more )? I don't want books, but multimedia informations.
I'm interested in sites , files in any format ,etc... that presents basic concepts, schematics,etc...I have discovered some but i need more info.
You can send me the info on my email:glodanr@email.ro
ergo
I just finished reading J.L. Hood's "Valve and Transistor Audio Amplifiers" two days ago and I would like to give it my highest regards and suggest it to everyone.
First I bought the D. Self book then R. Sloan book, but to me they are valuable as information source on minimising THD, calculating power supply etc. but both of them stick too much to one well known amp layout and both disregard the listening impression totally. After all, listening to music is a reason to build an amp in the first place...
JL Hood's book gives you an overview of different schematics, topologies and ideas both old and new and so gives a much better idea of the general picture. He's is a first book on the subject where author knows and accepts that there are differences between amps and even capacitors etc.....
Ergo
Jens
Highly recommended (must have): Allen Wright’s „The Tube Preamp CookBook" - www.vacuumstate.com
Jens
dice45
quote:
Originally posted by Jens
Highly recommended (must have): Allen Wright's "The Tube Preamp CookBook" - www.vacuumstate.com
Jens
Agreed, Jens,
I know Allen's book very thoroughly; it gives a very good insight into design philosphy. Allen explains how and why. This is rare.
However, if we are talking about valve amps, I would not like to miss:
Morgan Jones, Valve Amplifiers. 2nd ed., Newnes1999
Langford-Smith, Radiotron Designer's Handbook, 4ed. 1953, 1498pp (!), the bible
Valley & Wallman, Vacuum Tube Amplifiers, Mcgraw-Hill 1948, advanced bible
and for those able to read German,
Tietze-Schenk, Halbleiter-Schaltungstechnik, newest ed.
("Art of Electronics" is questionable from the didactic point of view ;not my opinion only, in German I would prefer the Tietze-Schenk),
valves again,
Barkhausen, Lehrbuch der Elektronenröhren in 4 Bänden, (1sted.1929, 4th ed.1960)
D.Ing.F.Bergtold, whatever you get your hands on: e.g. Röhrenbuch 1936. ( The author explains how directly heated tubes differ technically from indirectly heated ones and why the directly heated critters work more linear!)
Hint for anything possible with operational amplifiers:
Stout & Kaufman, Handbook of Operational Amplifier Circuit Design, McGraw-Hill, 1976. This indeed is a cookbook. You want to build an op-amp shunt regulator? it is in it, with all needed equations and eventualites.
'Nuf for now.
Greets,
Chucko
Douglas Self's "Self On Audio" is also very good. ISBN 0-7506-4765-5. The chapters on "Distortion in power amplifiers" alone are worth the price.
Much of this material is also available on Self's Amplifier Institute web site.
griff
on the subject of books, does anyone know of a subwoofer amplifier design book???
Damon Hill
I'll weigh in with my old and brittle copy of "Understanding
Hi-Fi Circuits", a collection of tube arcana by the late, great
Norman Crowhurst. Probably very difficult to find, but a
good sourcebook for designing tube amplifiers.
I'd be lost without my copy, assuming I ever scrape up enough
spare cash to buy some output transformers and finish building
my very first tube amplifier project. Got a half-built chassis
awaiting the money, parts and inspiration.
hifidaddy
A book, from which I learned a lot and understood better what is going on in an opamp or a discrete design, is also German, from former East Germany:
"Dostal: Operationsverstaerker"
There is one whole long chapter in the book on how to do it right with the high frequency compensation, which is incredible. When you read it, you know, that Douglas Self does it wrong and Leach does it much better.
To make things clear: this is a book about the _internal_ design of opamps, and _not_ about building amps using perfect opamp blocks.
regards,
Hartmut
traderbam
x
traderbam
Believe it or not I consider the ARRL Handbook for Radio Amateurs to be a bit of a bible when it comes to in-depth electronic circuit theory and detailed implementation. It doesn't provide audio circuits but the know-how has certainly been essential to my power amp design efforts.
My perspective on the sort of info that's out there is as follows (simplified and perhaps controversial):
level 1: sounds ok and doesn't explode
Basic electronics textbooks liike Horowitz and Hill. Device mfrs' application notes. Kits like those from Maplin UK. Most DIY projects published in magazines and on the web. Solid-state amp modules or amp ICs.
level 2: sound rivals mainstream commercial amps like Sony, NAD, Arcam, etc.
Specialist amp books, Doug Self website, some publications like Hood, most Pass stuff, good DIY copies of high-end designs, valve kits with good transformers. Stuff from academic institutions.
level 3: audiophile: sound demonstrably rivals Krell, Mark Levinson, Audio Research, Naim, etc.
Almost no info available that I can find.
I have had to teach myself how to get beyond level 2 and it is a hard and steep road. The sort of info that seems lacking is stuff like: what to measure, how to measure it and how to relate measurements to sonic chracteristiscs. What measurement equipment is needed? What sort, how much and why to use feedback? Dynamic stability and signal tracking accuracy. How to select cricital components such as output transistors and how to tune/match their characteristics in a real circuit.
If anyone can direct me to level 3 info I'd be most grateful. :cool:
mlloyd1
Harmut:
Is this the English version of the book you mentioned?
J. Dostal, Operational Amplifiers 2d Ed., Butterworth-Heinemann, 1993, ISBN 0-7506-9317-7.
If so, I agree with you! Walt Jung (op amp guru) say this book is "One of the best op-amp books currently available, with good technical analyses and discussions on basic and applied circuits."
Here is an Amazon link
It's expensive but worth it.
Michael
ftorres
Just my two (Euro) cents ;),
A few years ago, a friend told me some kind words about "Microelectronic circuits", 4th edition, by Sedra/Smith, Oxford University Press, ISBN 0-19-511690-9.
Not quite related to the thread's subject, but provides deep insights on basic bricks of amplifiers (diff pairs, feedback networks), with solved problems. Furthermore, it also makes a large use of MosFets and Jfets, which I have not found to be so frequent in electronics books...
hifidaddy
it seems to be that book. I found it when I searched material for amplifier design 10 years ago in the big Siemens company library in Munich/Germany.
100 USD is really expensive, though !
Another good reading is Motchenbacher/Fitchen on "Low Noise electronics". After reading you know how to do moving coil stages in preamps.
There are some interesting books on FETs, too, like the Evans/Siliconix book.
If you want state of the art schematics, you have to pay for an expensive subscription of the big Japanese hi-end electronic DIY magazine "MJ - Musen to Jikken". About 250 USD costs a year with 12 issues.
I found there the ML333 schematic, but without resistor values. Horrifying, really ;-))
regards,
Hartmut
relder
We used the 3rd edition for basically an intro to ideal opamps and transistor circuits at U of AZ. I recall it as being my favorite ECE textbook. (We often got stuck using a textbook written by one of the professors.) It covers the operation of the big three: BJT, MOSFET and JFET quite well. I only wish I had taken the second semester which began to get into amplifier circuits. (Being a CompE I probably took a software class instead.) Highly recommended if you want to know transistor basics and some of the building blocks of amplifiers, but it's not going to go into any detail on how to build a practical audio amplifier.
Having just received Douglas Self's Audio Power Amplifier Design Handbook and read just the first chapter last night, I'm a little depressed. So far the impression I've got seems to be that as long as you have an amplifier of very little distortion (like what is promised in the blameless amp later in the book) that there shouldn't really be any audible difference between amps. My initial reasoning from this is "why bother to build an amp if I can just go buy the cheapest amp with good THD specs and have no audible difference to something I build." This takes away the reason I bought the book, to be able to design and build a superior sounding amp. I'll have to read a few more chapters and see if my initial impression changes or not.
Chucko
quote:
I have to ask, what were you expecting?
I recommended Self on Audio because it was the first book I'd seen that rigorously analyzed the sources of measurable distortion - and their telltale signatures on the distortion plots - in the conventional "op-amp" power amp topology. Now Self definitely shies away from subjectivism and the "tweak of the week", so if you were expecting something trendy, you may have been wasting your money.
But if you really are a student of power amp design, I think there's a lot to be learned from Self's work. And there are a lot of commercial amps that aren't as good as his "Blameless" designs.
You may disagree with his design philosophy, but I think you need to understand it to be able to judge what might be an improvement - and why.
Damon Hill
Self, Sloan, Leach, et al, clearly have some favorite design choices,
but they all make it clear that there ARE choices, and a lot of them. They examined the trade-offs and selected designs that
worked well for them, and there's still plenty of choices left to experiment with.
Keep reading those books! I've waded partways through their materials and learned quite a bit, but I've still got a LOT to learn.
And I'm still slogging my way through my basic electronics textbooks:
Electronics Fundamentals, by Thomas L. Floyd
Electronic Principles, by Albert Malvino
The Art of LInear Electronics, by John Linsley Hood
and various other odd sources
One thing I do need is better source material on negative feedback principles that aren't too math-intensive. As firmly
entrenched as the basic Lin amplifier configuration is, there may
still be room left to play with zero and very low feedback amplifiers.
traderbam
Dear Relder,
I'm afraid that Doug's Blameless Amp is a very competent design but it is far from blameless. It is a level 2 design. The good news for you is that the distortion measurements he makes are not the whole story. In fact you will find many amps that meet these THDs and so on but sound crummy. And herein lies both the opportunity for you and the challenge: you must use your brain and, most importantly, your ears to deduce what matters, what doesn't and what Doug hasn't figured out yet. Don't be depressed...it isn't really that complicated, but it isn't always easy to see the wood from the trees. Being a little mad and obsessive would also serve you well in this quest! :D
blmn
Oh, yeah, Self does not see the light, yet, poor guy...:)
But, I'm with Damon, I think there are lots of things to learn from all of these guys, and about making good or bad amps, DIY amps sometimes will not reveal the best amp in the world, but the amp you made by yourself. Keep trying.
R. McAnally
Keep in mind that with ultra-low distorion amps it is not the amp that sounds crummy... your speakers and source units are creating 99% of the coloration and distortion at this point... the amp is not adding any "crummy" sound. Doug Self has figured out more than ANYONE about the inner workings of solid state amps, and from reading his books it is clear he will never advocate valve amps and is very clear about it. It isn't that he hasn't figured it out yet, he has and that is where he firmly stands. Give the man a break!
quote:
Originally posted by traderbam
Dear Relder,
richt
folks
where i can find a book that talks about pure class a
tube amp designs.
thank you
richt
R. McAnally
Check out www.partsexpress.com for lots of tube amp books.
Page generated in 0.08259391784668 seconds with 17 queries,
spending 0.01270175 doing MySQL queries and 0.06989217 doing PHP things.
