| keps |
I am building my first gainclone (LM3875TF). From where I am trannies are scarse, ordering online is going to be expensive. I found one toroidal tranny from some device with the following specs:
400VAC
PRIM 2x110V
SEC1&2 2x16V/12A
SEC3 18V/1A
Manufactured by Harbuch Electronics
Can I use this as a single tranny setup for my REV3(PCB) LM3875 kit?
Not to familiar with the tranny. It has 6 primary leads (2 browns, 2 blues, 1 white and 1 pink) 6 secondary wires (red &yellow, blue & gray and green & violet)
thanks in advance. |
| AndrewT |
are the pink or white connected to any other wire?
16V is a bit low but still workable.
Are you on 220Vac or 230Vac or 240Vac?
The transformer output will depend on the input voltage. |
| planet10 |
You can use the 16 V taps. This gives a bit less V than optimum (which i figure is 18V), but it will not have any trouble driving low impedance loads.
You will get 20-25 W into 8 ohms.
dave |
| keps |
| quote: | Originally posted by AndrewT
the pink ang white is not connected to anything, I actually figured it out. I use 230V with blue and brown, and that gave me the 16V output from both red & yellow, blue and gray.
Now another question is, should I connect one secondary pair to both PSU boards in parallel in AC1 and the other pair to AC2?
cheers |
| keps |
| quote: | Originally posted by planet10
dave |
Dave,
What would be the significant effect of a low voltage such as my tranny to the overall sound?
Would it clip in high volume levels?
thanks |
| djQUAN |
| quote: | | Would it clip in high volume levels? |
yep. |
| AndrewT |
with a lower voltage from the PSU there is less Vpk available to drive the load. i.e. it clips a bit earlier.
But the bigger advantage is that due to less heat build up from the lower voltage rails, the chip amp can more successfully drive lower impedance and higher reactance loads.
This may well give better sound quality with difficult speaker loads. |
| keps |
If I will be lucky enough, I'll get ta tranny at around 20-22 VAC.
Thanks you all guys! |
| Stuey |
| Keps, Harbuch are an Australian manufacturer of quality transformers who make Antrim designs under licence. |
