diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Need help..1st time DIY - Click HERE for Original Thread
ants
Guys,
I need help. I have alot of spare car audio subwoofers and I want to make my own subwoofer for my HT.
1 have
1 - Resonant Engineering SE 10
Fs 26.6
Qms 4.4
Qes .46
Qts .42
Vas 31
and 2 Resonant Engineering RE 10's
FS 21.5
Qms 4.37
Qes .39
Qts .36
Vas 75.6
www.reaudio.com
I plan to get the BASH 300W plate from PE.
Which sub will give me better results? Im a noob when it comes to HT.
What should I tune the enclosure to?
badman
Put the RE10s into a very large sealed box (7 or 8 cubic feet) and you should be golden :) Make the box solid, and one way to get around spouse acceptance factor is to make it a subwoofer coffee table :)
quote:
Originally posted by ants
Guys,
1 have
Fs 26.6
Qms 4.4
Qes .46
Qts .42
Vas 31
FS 21.5
Qms 4.37
Qes .39
Qts .36
Vas 75.6
www.reaudio.com
ants
7-8 cu ft..thats pretty big. How did you come up with that?
badman
Intuition :)
It would make for a lower Q alignment for the woofers, meaning that they will roll off slower, but the slope start higher. Tends to mean better sound quality, and better deep bass, and better coupling to room modes. You could model it, but for sealed, it takes relatively large changes in volume size to make the response change dramatically- in other words, an intuitive guess is usually sufficient assuming an experienced guesser :)
ants
thanks badman!
I'll give it a try..MDF is dirt cheap anyways.
If I were to build 2 towers (cant find sonotubes here), with your "intuitive guess" of 7/8 cu ft) would it be safe to assume on my part that each tover should have a volume of 3.5-4 cu ft? I dont belive i have room for a coffee table style sub.
xstephanx
yup, you got the right idea.
zlast
WinISD gives an enclosure of around 56 liters tuned to 24 Hz...
VAS is in liters correct ?
Cal Weldon
Surely there's a building supply store that sells ready-form tubes?
badman
Just to elaborate: a 7 or 8 cubic foot enclosure was meant to be total displaced volume- with bracing, driver, wall thickness, be more like 5 or 6 ft^3
Richard Ellis
Its' all in the math really...just a bunch of formulas...I came up with 16.90652931 Cubic feet @.707 Qtc. for the higher Fs one & 8.63 cubic feet for .9 Qtc.
The lower Fs one was 26.4626238 cubic feet for Qtc of .707
14.4 Cubic feet for a Qtc of .9
I love math & these formulas seem to work right on the money for me!
__________________________________Rick...........
PS.... Vas really can't be in litres...doesn't "ADD" up.
Page generated in 0.030493021011353 seconds with 17 queries,
spending 0.00820613 doing MySQL queries and 0.02228689 doing PHP things.
