diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Aura Va100 Evoluton Ii - Click HERE for Original Thread
ANALOG GUY
I bought it from my friend him told me that it's a best of integrated amplifier '96s.
I already received its PCB from R&D shop, they ask me for 100USD !!!
Hope
analog guy
ANALOG GUY
Aura VA100 II schematic, not include protection circuit (Patent Pending)
Thank
analog guy
ANALOG GUY
Prototype PCB, protel again !
Regard
analog guy
ANALOG GUY
Next week I'll find its parts and test PCB again after I finished my MODIFIED GAMUT D50 CLASS-A, need good chassis !
regard
analog guy
zeonrider
Nice AMP. Go!
Regards zeoN_Rider
Leolabs
Selamat Pagi!:D
Where did you get it??Seem that yo always get the chance to deal with good quality amps.
ANALOG GUY
http://amp8.com/tr-amp/foreign/aura/va100-2.htm
http://www.geocities.jp/tsoka/AURA-VA100.htm
4700uF/63V ?!? 50WRMS ?
It's my inspiration, how about that ?
Regard
analog guy
ANALOG GUY
2*TL084 for constant gain amplifier and 1*LM339 for input : output gain comparator.
TL084 used for special calculate voltage gain (AV) of amplifier when used with vary impadance load output (hard to drive speaker) on the circuit you can see only RF/RI for calculate AV but this IC are special more than typical amplifier !
LM339 used for comparator INPUT : OUTPUT voltage when there're some problem with output such as shorted output relay was disconnect from LM339 function, Vo/VI not equal in same dB
Example
MAXIMUM OUTPUT : INPUT = 30V : 1V = 29.54dB = NORMAL AV
SHORTED or LEAKAGE OUTPUT: INPUT = 0V : 1V = -INFINITE dB relay will be disconnect
Regard
Analog guy
Mitko1
I own one of these Aura amps. There is a problem: the servis guy who has repaired a problem with source selector (it is working now) didn't have a spare part for another problem. So he bypassed something that stabilize amplifire (when I turn it on) before the signal comes to speakers. The result is when I turn it on there is a loud crackel in speakers even if the volume is set to minimum. Which part did he bypassed and where can I get it? Is there a substitute for this part? I can take a picture of interior of Aura if necessary.
Thank You
Leolabs
quote:
Thank You
Possibly the protection circuitry.
ilimzn
Probably the output relay..
ANALOG GUY
Change your protection IC TL084 and LM393
Good luck
analog guy
vAD
Excuse! Has altered a few scheme, has received here such result
vAD
Sorry! Circuit.
DIGORA
2N5415 and 2N3440 in place of MJE
Page generated in 0.032993078231812 seconds with 17 queries,
spending 0.00804758 doing MySQL queries and 0.02494550 doing PHP things.
