diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Input source switching - Click HERE for Original Thread
Stuey
Hi there,
Just a simple one; for input source switching in an integrated NIGC, I want to use a simple Alpha rotary switch. Should I use a break before make switch, or will this cause noises like when used in a stepped attenuator?
Cheers
Stuey
Nuuk
Break before make is fine for source select. ;)
Stuey
Thanks Nuuk.
Leolabs
Try some quality rotary switch like Lorlin,CK....
AndrewT
break before make will leave the input disconnected for a short while.
Is the amplifier stable when the input is left floating?
Some inputs need to see a lowish source impedance/resistance to remain stable.
rabbitz
.... or an Elma 04-1261. Got mine from Michael Percy. The Alpha can be very fickle and had one that lasted a month as it just gouged tracks.
The LM3875 NIGC I have has no problems with a break before make switch.... not a peep.
Stuey
Sorry guys; I hadn't noticed you'd replied since my last post.
I ended up leaving the amp with only one input at this stage (my first build) so as to concentrate on getting all its general operation correct first. It's now running well.
I've changed my mind to build a simple and separate pre-amp so that I can incorporate a phono stage and a remote volume control.
Andrew, thanks for the input again - I'll keep that in mind.
Cheers
Stuey
Page generated in 0.020688056945801 seconds with 16 queries,
spending 0.00718856 doing MySQL queries and 0.01349950 doing PHP things.
