diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
One of my OPA541AP short without knowing why - Click HERE for Original Thread
5150ed
One of my OPA541AP short without knowing what is the reason.
I am using 100mf Blackgate N with 1000mf Balckgate Standard and haveing very wonderful result however, I want to try only 100mf Blackgate N which is said to have best mid and high frequency.
So I remove the 1000mf standard, without touching any others parts at all.
But when I turn on my amp there is a lound noise from one of my speaker and noise from the other side.
So I check both chanel, nothing wrong. I did try again, same thing happen.
Then I connect the 1000mf standard back but one of my chip is short resulted in 29V DC offset at the speaker terminal. :bawling: .
The worst thing is I still do not know why??? :whazzat:
Nordic
My guess was it formed part of an RC network, and you basicaly changed the cutoff frequency for your amp to the point where it made the chip oscillate to death.
100db
My friend, you may still lucky enough.
Check your grounding, power and signal ground may loosen or separate when you remove the BG :D
I've a similar symptom when I forgot to connect power gnd. to signal gnd. ;)
Page generated in 0.018424987792969 seconds with 16 queries,
spending 0.00802374 doing MySQL queries and 0.01040125 doing PHP things.
