diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Krell Clone on 60V rails - Click HERE for Original Thread
dshortt9
I have the Delta Audio KSA 50 boards and wish to run them on ~58V rails. I have PLENTY of heatsinking. What parts should I change to what values? Will take all suggestions with caution. Willing to use a bit less bias. Should I use the I/V limit circuit or eliminate it?
TomWaits
I have always had an interested in this quest too. Waste of time? I don't know?
Has anybody used more than 6 output devices per channel in their build (3-NPN & 3-PNP) ?
Shawn.
jacco vermeulen
12, Sanken 2SA1216/2SC2922.
Search for Stuart Easson's posts on CCS on the KSA thread.
pinkmouse
Exactly what I was just about to type. I have a b@stardised Krell running in class B with 5 pairs of outputs on 55V rails, but it's still with a friend. When I get it back I'll post pics.
jacco vermeulen
Allow me to supplement Al's words by welcoming you to the f@tB@stard (Austin Powers copyright) amp club
TomWaits
quote:
Originally posted by dshortt9
...What parts should I change to what values? Will take all suggestions with caution. Willing to use a bit less bias. Should I use the I/V limit circuit or eliminate it?
Any takers for dshortt9's questions or is there no concern?
quote:
NICE ! :D
quote:
Again, very NICE! No tweaks involved? Could it be fired up with +_60 VDC? It sounds like you guys did not modify anything?
Shawn.
pinkmouse
I tweaked a few resistors in the tails of the input stage, can't remember what values I used, but it's all Ohms law to keep the currents through the diodes similar to the 35-40V version.
I removed the IV limiting in my version because of space constraints, but it depends on your usage as to if you use it or not.
dshortt9
Thanks for the info. I have plenty of matched 2sa1216/c2922 to use. F@tB@stard KSA 200 here I come. The front end ran around 7 mils I think. Could I change the 27V zeners to accomplish the same?
dshortt9
So if I stay with the 27V zeners there will be a 33V drop across R108/R109 @7ma. 60 volt rail. That means I would need a 33/.007 or 4.7K resistor. Yes?
dshortt9
Would R112/R116 - R113/R117 also need to be 4.7K?
pinkmouse
Hmm, I'm at work at the moment, so I don't have access to my schematics and stuff, but I'm fairly sure I didn't go that high. For some reason, 3K3 rings a bell.
dshortt9
The 9.1K resistor, in series with the 1.5k, with a 30V drop would indicate that 3.3ma is going to the diff pair. If I used a 47V zener then 50V would be dropped by this resistor giving a value of 50/,0033 or 15K. Sound good?
jacco vermeulen
My KSA boards run on different voltages.
For the time being both rails are not regulated yet untill i have the voltage regulator boards from Bob Ellis's Groupy B worked out.
No V/I limiters as they have only 35Vdc on the output rails and the output devices have a tremendous SOA.(for a BJT)
Depending on the type of output device used and the number a V/I limiter is not necessary.
Unless you intend to parallel a huge number of output devices alla Threshold Stasis amps i'd use a V/I limiter on 60Vdc rails.
Which i do on the Leach amp boards i'm working on that has 10 output devices, supposed to run on 75 Vdc for the output stage rails.
The few extra volts on the front end rails are to enable to drive the output stage almost to the output rail voltage, without having Vbe losses.
(some will disagree and talk clipping chit-chat but plenty designers who have done this, including the master himself)
dshortt9
Thanks for the advice. I am thinking of making use of some DN2540's that I have to make 3.5ma constant current sources for the front end. hat would solve everything.
AndrewT
I am planning 6pair output stage using twin drivers (a bit like KSA100) on +-42Vrails.
Not started the build.
You need to scale:-
r103/107
r108/109
Why change r112/116/113/117? They are the load for the LTP.
Keep the zeners near 24V to 30V. Arrange for a zener current of slightly more than 10% of it's maximum dissipation. Consider adding a ceramic cap across the Zener to hold constant voltage and attenuate noise.
If using 500mW zener @ 27V then Iz>=2mA.
LTP current ~=3mA
Total current through r108>=5mA. But you need to check this at both minimum mains supply voltage and at maximum mains supply voltage. Check maximum dissipation on r108/109.
I103/107 ~=0.8mA
You may want to reduce r125 slightly to ensure a good range on setting output bias. Particularly if you want a high Iq. r124~=2k0 and r125~=510 may be a good starting point.
R144 (wrongly labelled low bias) could be brought in/out by relay. Summer setting (r126 on it's own) = standby or sink overheat.
dshortt9
Right, changing r112/116/113/117 was just brain dysfunction. After considering everything I think I'll use a lower voltage, around 40 - 45 volts. I wanted to use 60 simply because I already have it built from a previous project. Another option is to wire the 2 primaries in series and use 30 volts.I could get wild and bridge 2 amplifiers at this voltage for more power. might be an option. Thanks for the info on the other resistors, etc.
AndrewT
bridging will defeat the ClassA function.
A bridged amp thinks it is driving half the load impedance.
KSA50 can only manage 1.9A bias and 3.8Apk. The 8ohm speakers will appear as 40hm loading. 4ohm loading will stay in ClassA upto 15Vpk (about 29W).
That equates to 58W into 8ohms. What a waste of two channels of amplification.
A ClassA spec PSU is a different animal from a ClassAB PSU. They do not swap over very well.,
jacco vermeulen
quote:
Accuphase P102
AndrewT
Hi Jacco,
I do not understand.
Are you saying that Accuphase were daft enough to offer a bridging option in a full ClassA amplifier
or
That Accuphase changed the bias to keep the bridged amp in full ClassA
or
That Accuphase conned the populace into believing that spending good money on a ClassA amplifier could increase the ClassA power by simply bridging?
Which option do you think is closest to the twisted truth.
Or
Is there something I have misunderstood about ClassA current?
jacco vermeulen
Among several other manufacturers Accuphase produced fully symmetrical class A amplifiers.
For the output voltage an amplifier may see only half the impedance in bridged mode. The output current still only views the same loudspeaker.
An amplifier that does 50 watts class A in 8 ohms still will deliver 50 watts in class A in 8 Ohms when the channels are bridged. Bridging doesn't increase class A output level, nor does it decrease it.
A major difference besides different slew and damping numbers is the highly increased AB output power.
All in all, a bridged class A amplifier has several advantages.
For really high power applications it is often cheaper, there's no linearity between component voltage rating and component price.
The disadvantage is a somewhat lower efficiency for a bridged amp that has the same output rating as a non-bridged version with higher rail voltages.
A lot of the famous high power class A amplifiers only did a minor portion in class A.
Check the Luxman M-05 thread for instance. Very expensive amplifier, advertised as 105 watts in 8 ohms amplifier. 105 watts continuous in AB maybe, the bias was only good for 36 !
Why someone would bridge a class A amplifier that has 60Vdc rails illudes me, but that's his choice.
AndrewT
Hi Jacco,
sounds like you are confiming
did they define the ClassA and ClassAB powers into the recommended loads?
dshortt9
You misunderstood me, I meant use 30 volt rails and then bridge the 2 amps.
Unless I missed something, doesn't the Krell move into class AB when the class A limit is exceeded?
jacco vermeulen
Sure,
there's still some contraversy overhere on the term class A amplifier.
Most of the big class A amplifiers weren't fully biased, others used circuitry to raise the bias on demand.
Giant amplifiers like Jeff Rowland's Model 7s were measured at 450 watts in 8 ohms but only a small fraction was "true" class A.
A brand like Perreaux made an entire series of amplifiers that did 10% in class A mode.
And with good reason, above 50 watts/8 the dissipation becomes quite an endeavour. I've only managed to go as low as full class A to 3 ohms on the KSA without excessive fan noise, while i was aiming at 2.
30Vdc rails and bridging is a very good combo, with SOA in mind.
The Accuphase P102 had 20Vdc rails, 2SJ76/2SK213 Mosfet drivers are bad for the economy =>
dshortt9
Now, If I bridge 2 amps with 30V rails could I use NP's X'ing trick by routing the feedback from one amp to the other one and vicey versy?
Page generated in 0.057281970977783 seconds with 17 queries,
spending 0.00971842 doing MySQL queries and 0.04756355 doing PHP things.
