diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
To decouple or not to decouple. - Click HERE for Original Thread
Colescuttle
I'm putting together one of Peter's LM3875 kits in a monobloc format. I have 4 Jensen 4 pole electrolytics left over from another project. Would I gain anything sonically by inserting one each in the + and - rails between bridges and amps? I'm using a 300VA/22v Plitron transformer.
Thanks!
Nuuk
There's one way to find out! :att'n: ;)
angchuck
The jensens are so good that you should make a separate velo board and hook them up as shown. If you have 2 caps, then just use one half of the configuration. Then you can compare power supply configurations and have more fun.
Colescuttle
Your diagram didn't come through. Could you attach it to an email to george_cole*bellsouth.net.
Thanks for the help.
AndrewT
re the 4pole electrolytics.
Can you explain the difference between IN & OUT?
Alternatively, what is connected internally?
angchuck
Hey Andrew,
This diagram was posted by Chris (ClassD4sure). Maybe the experts in the forum can chime in on how the jensens work.
i don't know how these 4 poles Jensens or BHC's are constructed. But they are polarised with 2 +- terminals, and they are not 2 radial caps rolled into one. Either - terminal works with either, or both + terminals.
Maybe the jensen white papers can help, it didn't really help me answer your question. I have no engineering background.
http://www.jensencapacitors.com/aud...pers/4pole.html
I am pretty much a newbie, but i am always curious. I tried // 2 normal caps in series but that didn't work like i imagined. :cannotbe:
Anyway, i was telling George that this was the best configuration i have built for my ucd180 and nigc. The regulated PS was a close second and third would be the capacitance multiplier. But that one runs the amps so hot, i think it might have caused my ucd's some inherent problems. Thus, unregulated snubberised PS would be my unqualified third placed. And 8X Pana FC's straight up were my least preferred, but they are still pretty good.
In the back of my mind, the reputation of Blackgate FK looms.
Chuck
AndrewT
either // (parallel) or series for the pair, not both.
Page generated in 0.023557901382446 seconds with 17 queries,
spending 0.00813842 doing MySQL queries and 0.01541948 doing PHP things.
