diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Opamp decoupling - Click HERE for Original Thread
Khron
I'm in the process of building myself an active 2-way crossover (Nuuk's discrete buffer for the input, TI TLE2072s as active devices and OPA627 on the outputs).
QUESTION:
Does each opamp need a 0.1uF cap
1) between each of the supply rails and GND
2) between the two supply rails (V+ to V-)
3) both of the above ?
FastEddy
... but one for each rail driving both op-amps would probably do the trick.
I would build it first, check it out, before adding any more caps than necessary other than prudent practice.
(You might look / see TI's app. notes = http://focus.ti.com/docs/prod/folde...pplicationnotes & http://focus.ti.com/docs/prod/folde...pplicationnotes )
:smash:
Page generated in 0.018254041671753 seconds with 17 queries,
spending 0.00834274 doing MySQL queries and 0.00991130 doing PHP things.
