diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
This amp is Good or Not? - Click HERE for Original Thread
Bushulo
I am wondering if any one has built this amp. Output power is 360 Wrms under 8 ohms or 550 Wrms under 4 ohms Any Comments and suggestions?
http://users.swing.be/edwinpaij/ampli_mosfet_360_w.htm
Bushulo
kubeek
see this thread: http://www.diyaudio.com/forums/show...77&pagenumber=1
I built a few of these, they work fine, but I had to do some minor changes in design.
darkfenriz
For such high powers I would add some short circuit/SOA and DC protection.
parsecaudio
Hello Bushulo
I viewed the schematic.
Some considerations on this.
1) the zener diodes are not a good idea to use for voltage drop or biasing like this circuit.A simple resistor is much better for noise and distortion.
2)in this configuration,the supply voltage on first and second stage must to be higher respect to the mosfet stage(4-5 volts) and stabilized
3)the circuit have no protection.For this high power a DC and SOA foldback protection are needed
4)the amount of NFB is high.Take care on oscillations and stability problems.
5)you do not use the IRF mosfet type but only the 2SK-2SJ.This devices are thermal stable when the quiescent current are across 200 mA each.200mA x 12 mosfets is a very high heat to be dissipate at no signal input
6)more important:the circuit have no value for the components.For this you should to be pay.
I think that a more correct schematic can also built.
I don't like this
anatech
Hi parsecaudio,
I don't like this design either.
The zeners are used to keep the transistors within their ratings, and without an AC voltage drop. Adding resistors would lower the amount of AC signal to the next stage.
I do agree with the rest of your comments.
-Chris
parsecaudio
Hi Chris
Sorry for my mistake.
You are right:the D1-D6 in this circuit are necessary because the Vcb max of the BC550-BC560 are lower than your respective supply voltage rail.The zener cause a DC voltage drop.
Why not use the low noise 2SC2240-2SA970?
They are 120V max and the zener are not necessarily.
Vittorio
kubeek
I can offer you a better schematic, I have this amp like a project from some magazine, including DC servo, current and DC protection and limitation detector. I also have the driver circuit + DC servo in Eagle on one board.
anatech
Hi Vittorio,
It is possible that the power rating may be exceeded as well depending on the tail current.
Maybe the same reason they didn't provide a regulated supply for the front end with a 5 volt level over the main supplies. I don't think the driver stage can properly handle the gate charge anyway.
-Chris
parsecaudio
I agree Chris
This is for the T9 and T10 moreover.
Many years ago I have built a similar (Dynaco) amp.
Symmetrical dual differential input stage and second cascode stage with power mosfets on output stage.
In my first power on the amp it did not work because I forgotten to mount the two passive load resistors across the collector of the two transistors(named in this circuit T9 and T10) and the output of the amp .
An oscillation it was produced.
I had to add some compensations before that you noticed me of this error......
:smash:
:dead:
anatech
Hi Vittorio,
If we all listed every one of our mistakes ..... :D We can look back and laugh now.
Don't like that input stage.
Give me J-fet differentials any day. Cleaner sound.
-Chris
darkfenriz
quote:
Originally posted by kubeek
....but I had to do some minor changes in design.
Let me guess: caps parallel to zeners and fried bc550/560 ?
:D
parsecaudio
Chris
I'm completely of agreement with you.
Also I have abandoned this design some years ago for the J-fets.
I have seen some other projects on the linked site:it seems that
the power mosfets are the IRF type.
If this is true,the amp are not suitable to built because not thermal compensation are present.
A better design can be made....:rolleyes:
kubeek
nn, I used a sligthly different schematic from the beggining (see the thread I reffered to), it has diff the current sources connected to +-15V, DC feedback and thermal sensing transistor to correct the IRFPīs gates.
I just added 150pf parallel to first feedback resistor because of oscillations, zeners on gates, and have added +-10V for the VAS stage. Also changed the DC servo connection by crossing the 1Meg-100n-1Meg by 100K because it oscillated at say 0.3Hz.
parsecaudio
Hi darkfenriz
Yes,on some condition,with large alternate input signal,the Vcb limits of the BC550-560 can be exceeded with power supply of 85V for the input differential,and a risk of destroy is for the current regulators.I don't know the current on this stage,but this is very low due to the power characteristics of the BC.
Moreover, as Chris has said, the second cascode stage has some problems to drive the gate capacitance of the output mosfets,it seems that they are the IRF devices.
If this is true,a thermal runaway it happens.
This is not a good design... :smash:
:bigeyes:
Cheers
parsecaudio
Hi darkfenriz
Yes,on some condition,with large alternate input signal,the Vcb limits of the BC550-560 can be exceeded with power supply of 85V for the input differential,and a risk of destroy is also for the current regulators.I don't know the current on this stage,but this is very low due to the power characteristics of the BC.
:bigeyes:
Cheers
anatech
Hi kubeek,
Yours are stable then. How do they sound in a house?
-Chris
kubeek
I donīt use them for usual audio, so I canīt tell.
I play bassguitar through one pair bridged, but I donīt have proper preamp ready yet, so I canīt even tell if it is good for bass.
Anatech, could you please have a look at the other thread? thanks
parsecaudio
Hi darkfenriz
:bigeyes:
Cheers
Bushulo
Hi Guys,
Thanks for the suggestions and your replies. The fact is I paid for this project three years back.
The schematic is in PDF format with component value. But im afraid to post.Because of copyright.
Please advise me if it is legal.
Bushulo
kubeek
I dont think it is a problem, its almost impossible the manufacturer would find your posts and try to make anything out of them.
Do you have the PCB for that project?
Bushulo
Hi Kubeek,
Got a pair of pcbs and setup guide documentation
My e-mail ID: bushulo@gmail.com
Bushulo
norvbul
Hi Bushulo
Can you send me a copy of the schematic, layout diagram and any other documentation you may have for this amp.
my email address is norvbul@yahoo.com
Thanks in advance
Norvbul
Page generated in 0.050228118896484 seconds with 19 queries,
spending 0.00756788 doing MySQL queries and 0.04266024 doing PHP things.
Copyright Đ1999-2008 diyAudio.com
Please support our sponsor.
