| kesa32 |
hi all........just wondering if you can fix foam surrounds at all without replacement............l was installing some new sub drivers the other day and one of the screws slipped sideways and l hit the foam surround slightly causing a slight scratch in it...:(
l'm concerned over time this might tear open with the surround flexing....is there any glue l could use on this at all??.....any help would be appreciated as l got these from overseas and dont want to have to get a kit if l dont have to........cheers ken |
| Cal Weldon |
| And remember to encircle the screw with your hand (make a fist around) to avoid this in the future. Sorry you had to learn the hard way. Good luck with the repair |
| jleaman |
| I use clear silicone. Works well. :D |
| kesa32 |
| quote: | Originally posted by sreten
If the foam is split use a small amount of something like "copydex" to close it.
thanks......yeah it's not split....just a a small scratch,but over time might get worse .....so l'll check out this stuff and some others too that have been recommended.thanks again
http://www.ryman.co.uk/Copydex-Adhe...-0625102293.asp
:)/sreten. |
| quote: | Originally posted by Cal Weldon
LOL.yeah my bad.......l've installed drivers before and should've known better.......cheers ken
| quote: | Originally posted by jleaman
l'll look into this as well.....guess l'm just concerned on what might react with the surround material....cheers ken |
| jleaman |
| quote: | Originally posted by kesa32
The reason i use silicon is because it wont harden or crack It remains flexible A little stiffer than the foam but if you use a small amount of it on the rear of the surround it should be fine. |
| kesa32 |
[QUOTE]Originally posted by jleaman
The reason i use silicon is because it wont harden or crack It remains flexible A little stiffer than the foam but if you use a small amount of it on the rear of the surround it should be fine. [/QUOTE
the scratch is on the front of the surround , so l'll have to use the stuff sparingly .....thanx ken |
