diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Driver to build an good subwoofer. - Click HERE for Original Thread
samsagaz
Hi, i have an paradigm subwoofer, and i want to upgrade my system, i want to build my own subwoofer, wich driver recommends me? the Room size is 23x13 Feets.
i want to down to at least 20hz!. and i think that 12" will be ok. :)
jleaman
What size is you'r Paradigm ? whats the model ? Is that sub loud enough for you or you want more now ?
samsagaz
Paradigm PDR-10 is the model
- Single driver, bass reflex, high-velocity low-turbulence resistive port, built-in amplifier
- 120 watts RMS / 360 watts Peak
- 254-mm (10 in) carbon-fiber-reinforced composite cone, 38-mm (1-1/2 in) voice coil
- 27 Hz (DIN)*
- Cutoff Variable 50 Hz – 150 Hz
- weight 12.5 kg / 28 lb each
these are the specs of the subwoofer that i have right now.
I want to sell it and build another with more power and maybe that go a little low (20hz).
jleaman
I know all the paradigm Sub's. I'm a paradigm speaker fan.
Well you need to tell us if you need more bass or are you just looking to build something. Ie starting off with a sub.
samsagaz
well i want to improve the quality of my sub, thats all, i want to go more deep, i think that the paradigm dont down to 20hz.
and more power will be great too :)
mike.e
As a minimum
Adire 12" (shiva for example) on large ported box.
~300w Plate amplifier
Done!
samsagaz
and as a maximum? :D
tktran303
How long is a piece of string?
18 inches. 30mm one-way x-max to be exact.
http://www.tcsounds.com/tc5200.htm
samsagaz
damn thats amazing :D 2000Watts RMS.. (6000 maxium peak) :S
its really too big for my room :D
i need some small :)
i read that scan speak 23w/4557t00 is good...
zlast
If you are looking for small enclosure size, look at the PEERLESS XLS or XXLS line:
http://www.tymphany.com/products_Peerless.html
ANother option would be an Ascendant audio driver, which would probalby cost less than a PEERLESS driver, not sure about shipping to SA:
http://www.ascendantaudio.com/assassin12specs.html
In either case you will need adaquet amplification and be able to build the enclosure.
samsagaz
For amplification i want to use some ClassD Kit
Page generated in 0.029100894927979 seconds with 17 queries,
spending 0.00812197 doing MySQL queries and 0.02097893 doing PHP things.
