| burnedfingers |
Can I use (2) 5Z4P tubes in place of the 5AR4 tubes in my Quicksilver 8417 amp?
Each mono block 8417 has two 5AR4 rectifiers. |
| refference |
Hi burnedfingers ,
It is not a good idea , because the 5Z4 max. out. current
is only a half of 5AR4 capacity ( 125 mA versus 250 mA )
The max . input RMS voltage is 350 V AC for 5Z4 versus
550 V AC for 5AR4 .
The 5AR4 / GZ34 is a very easy to find tube , with many
manufacturers .
Regards ,
Carlos |
| refference |
In time ...
If the voltage is not a problem ( lower than 350 V AC ) ,
you will need 2 x 5Z4 , in the place of one 5AR4 , to
have the same current capacity .
Carlos |
| burnedfingers |
Carlos,
Thanks for the info. I will look for some 5AR4's. |
