| rnzr |
Hi
I want to recable my Pro-Ject Debute turntable with the DH-Labs BL-1 balanced interconnect cable (with rca's).
I've done many "telescoping shield" (shield is grounded on the signal side of the rca's) rca interconnects but don't have experiences with the turntable wiring, does it work good on turntables too...(?)
So should I terminate the shield on the turntable side to the ground like "telescoping shield" type cable? (The cable must soldered directly in turntable, it doesnt have rca jacks) Or should I left the shield untouched?
Suggestions are welcome...
Thanks |
| Gooch |
Hi rnzr
This is what I would do take one wire solder it to the center pin of the RCA the other wire to the shield of the RCA now the Shield of the balance cable would also be attached to the shield of the RCA but not at the turntable hope this make sense
Dave |
| rnzr |
| so i should solder the shield wire to the rca ground? and leave the shield open at the turntable side? |
| Gooch |
Yes that's right
Dave |
| rnzr |
| ok, thanks but can you tell me Dave why is that better than the opposite option? better noise cancelling? |
| Gooch |
Well don't quote on this I guess noise coming from the TT would be cancel out if the shield was connected at the TT. But if you have to solder right to the TT then it might be harder to do then the other way I don't know what your TT looks like. Try it either way and see if you hear any difference it can't hurt.
Dave |
| rnzr |
thank you for your reply's!
rewiring done and results are very good :cool:
click on a pic to see gallery...
| Gooch |
RNZR
Nice work they look really good glad you like it.
Dave |
