diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
What to tune my enclosure to? - Click HERE for Original Thread
rocko1290
I am building a sub and I need help choosing a tuning frequency.
Here's what I got:
--Dayton DVC 15" (Tempest clone)
--250 watt Rhythmik Audio amp
--250 liter ported enclosure
What would be a good tuning frequency for this project, and how do you decide on a tuning frequency?
--Thanks
GhettoSQ
Hey rocko,
Didn't you model with a 200l box and get 19Hz below? My winISD doesn't have the dayton; what does yours suggest?
From the curve in your thread below, I think you could go a little lower, maybe 15Hz, but I'm far from the most experienced here :)
rocko1290
quote:
Originally posted by GhettoSQ
Hey rocko,
From the curve in your thread below, I think you could go a little lower, maybe 15Hz, but I'm far from the most experienced here :) my enclosure.
Do you have WinISD Pro? If so, just click (new project) then click (new) and add the following parameters in there for the 15" Dayton DVC (model: DVC385-88).
Qes = .39
Qms = 12.28
Fs = 20.4 hz
Vas = 9.92 cu. ft.
Mms = 197 grams
Re = 2.6 ohms
Le = 1.81 mh
Xmax = 15.1 mm
WinISD will automatically calculate the other parameters that you do not enter.
GhettoSQ
OK, it gives an freq of 20.88Hz, but IMO the curve could be flatter at 24Hz. It's all +/- 1db. What are your goals?
With a 4" wide port of 3.75" you would have a tuning freq. of 23.92Hz, f3 around 21.5. You can bring your f3 down to 20.5 with a tuning of 20.88Hz, vent 4" by 5.83" :)
mashaffer
I like organ music so this is the direction I would lean.
mike
Page generated in 0.020785093307495 seconds with 17 queries,
spending 0.00704885 doing MySQL queries and 0.01373625 doing PHP things.
