diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
internal shielding - Click HERE for Original Thread
camotecue
guys,
just a newbie question: does one have to ground the internal shielding of a tube?
Geek
Depends on the application and layout.
Certainly it's preferable. But if it's inducing ground noise, try grounding it through a 1Meg resistor shunted by a smallish cap, say 0.01 to 0.047uF.
camotecue
geek,
thank you. it's just now i connected to the internet.
jarthel
Mr. Broskie suggest a .1uF cap to ground. but he also said that you can connect it directly to ground.
Geek
Yeah, the value isn't that critical.
I would listen to Broskie in this case over me :D
Page generated in 0.068254947662354 seconds with 16 queries,
spending 0.03636098 doing MySQL queries and 0.03189397 doing PHP things.
