diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Is there a Web-site that you can find transistor replacements(by specifications)? - Click HERE for Original Thread
DJG
Is there a Web-site that you can find transistor replacements by entering the original transistor's specifications(like U, I...)?
DJG
peranders
www.questlink.com isn't perfect but you can get some good info there.
jackinnj
search engines -- for instance, if you go to International Rectifier www.irf.com , you can search by P or N-Channel, voltage, power, RDS, package etc. On Semi, Fairchild, Toshiba, Hitachi also have parametric search engines. If there's just a listing you can always save as a *.txt file, dump it into MSExcel and sort by column heading.
peranders
I forgot that you can also ask the dudes here. We probely can help you.
Page generated in 0.018227100372314 seconds with 17 queries,
spending 0.00749683 doing MySQL queries and 0.01073027 doing PHP things.
Please support our sponsor.
