diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
ripple values in B+ supply - Click HERE for Original Thread
Antonio Tucci
In a 2-stage 2A3 amplifier (6C45P-2A3) which should be the values of ripple in the B+ supply of the first and second stage ?
Klimon
About 70mV max. for the output stage (30 or less being very good), 10mV for the input stage (3 or less being very good), other people might have other standards...:D Edit: that's my baseline for two-stage single-ended IDHT, dunno what's the drill with DHTs.
Simon
sorenj07
basically run a bunch of sims in psudii with real-world chokes and caps etc. and build the best one you can afford/have room for.
AndreasS
quote:
Best answer:
http://www.audioasylum.com/forums/s...ages/47106.html
regards Andreas
Page generated in 0.020595073699951 seconds with 17 queries,
spending 0.00792146 doing MySQL queries and 0.01267362 doing PHP things.
