diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Hybrid Aikido-ish gain stage - Click HERE for Original Thread
Fuling
How about this circuit for driving a Mosfet power follower?
ECC86 is the european version of 6GM8, before anyone misreads and asks why I´m using ECC88 (6DJ8) at such low plate voltage.
A short explanation of the schematic:
The triode is of course the actual gain device, operating at 15V 2mA. The plate is loaded with a 2SK170-based CCS and direct coupled to a cascoded Jfet White follower.
This *should* give that whimpy little triode pretty much optimal circumstances to do it´s job as a voltage gain stage.
IME this tube is hardly capable of driving anything by itself, but this follower should be a very easy load.
JoshK
This circuit looks pretty cool to my newbish eyes. Have you built it yet?
Fuling
I´m working on it, will probably finish it tomorrow
Fuling
The circuit is built and tested and the results are very promising!
50kHz with a IRFP260-based follower on the output is no problem.
I´m planning to run much more tests on this one later, when I can borrow some better test equioment.
Page generated in 0.018889904022217 seconds with 16 queries,
spending 0.00858140 doing MySQL queries and 0.01030850 doing PHP things.
