diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
fuse before AC switch? - Click HERE for Original Thread
jarthel
I've read suggestions from other people saying to put the fuse before the AC switch.
any reason behind it?
thank you.
AndrewT
I would go along with fuse first.
That way anything downstream that goes faulty and draws excessive current is protected by the fuse. The fuse won't save the faulty component and probably not limit consequential damage either, but will stop the mains cable catching fire and worse.
There are some models of IEC inlet and inlet filters that are fused. They always (well nearly always-but I have never seen an example) have the fuse first.
quasi
I agree with AndrewT. The fuse should be the first termination point for the active mains connection. I always go to the fuse first, loop then solder the connection. I then go from the other side of the fuse to a terminal block and feed components from there.
Cheers
Quasi
Page generated in 0.052177906036377 seconds with 16 queries,
spending 0.00860882 doing MySQL queries and 0.04356909 doing PHP things.
