diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Mesurement electret mic problems - Click HERE for Original Thread
Bazukaz
A few days ago i got a JBL measurement microphone from LSR4300 monitor set. The mic was designed to work with these speakers(the speakers are active and have mic input to equalise frequency responce automatically).There is +15V written on mic jacket on speakers.
I want to be able to connect this mic to a sound card.
I disassembled the microphone cover, and found a few components inside.The is one IC , JRC 4580(or 5616?) , and a few caps and potentiometer.
On the little PCB , there are three connections(Vcc , Gnd , A-Out).The VCC is 15 Volts , ground is ground , and A-Out i suspect to be audio out.The +15V is red on mic's minijack , white is A-Out , and ground is shield. The two other connections go to mic capsule.
So , this is mic amp.
I built a little regulated +15V power supply , and connected it to the minijack of microphone.It works, but i am having lots of 50 Hz Hum in SpectraPLUS ... Ground loop ? Touching the microphone increases this hum. I tried to replace the regulated PSU with 9 volt battery , but the things didn't change , so it is not supply's fault.I included the connection block diagram.
Lukas.
Bazukaz
So, no ideas ?
I also observerved that touching the microphone's case together with PC case while holding peace of wire diminishes the hum almost completely.
Lukas.
Page generated in 0.067786931991577 seconds with 16 queries,
spending 0.05703282 doing MySQL queries and 0.01075411 doing PHP things.
