diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
Bi-Amp for T-AMP -- How to. - Click HERE for Original Thread
panomaniac
A new thread to discuss using the small T-AMPs in a bi-amp set up.
This is something a lot of us have done, but it doesn’t really have its own unified thread.
We should add this info to the WIKI and try to get an admin to add the WIKI/FAQ lik as a sticky post in this forum.
So you want to bi-amp/bi-wire your system? You want more power, right? So do we all. But this will NOT get you much more power. Just a tiny bit more. Still, it's a good idea and can sound nice. With T-Amps it is not expensive to try.
Here is how to do it:
You use one amp channel per section of the loudspeaker. If you have a 2 way speaker, you can use the left channel to drive the woofer and the right channel to drive the tweeter. So you would need 2 amps for a stereo setup. With a 3 way speaker you need 3 amps for stereo. (6 channels)
Your speakers must have separate terminals for each section. With the small T-AMPs, (AMP3, AMP6, Sonic Impact, Charlize, Super-T, etc.) the grounds must NOT be common. So you have two posts per section. 2 for the woofer, 2 for the tweeter. Connect the amp channels one to the tweeter and one to the woofer and Volia! you are bi-amped.
How to run the inputs?
For the simple passive crossover type system (in the speaker), you will need to split the input signal so that it goes to both the left and right inputs on your amp. That is because the filter is after the amp, in the speaker, so each channel gets the full range signal. One amp will get Right, the other will get Left.
It is easy to split the signal, just run one wire to each input cap from your volume control. Or run directly from the RCA connector if you are using a preamp. Keep your wires short.
That is a passive bi-amped system. You don’t get more power, but you will get more channel separation and isolate the tweeter from the electrical circuit of the woofer.
I invite comment and discussion of this, but let’s try to keep it to the T-AMPs.
Wiring diagrams are welcome!
phn
Here are a few ideas.
The real benefit with bi-amping, as you all know, is active x-overs. It remains a secret in home audio because it's virtually impossible to market. But this is DIY.
A wild idea, which is not wild at all, is to build a chip x-over, rip out the passive x-over in the speakers and mount the active x-over and T-amp of choice. In other words, plain active monitors. I don't know about all speakers, but older Altec and JBL speakers should lend themselves well for this.
bumblebee
Hi guys. My first post.
preiter
Bi-amping using T-Amps is no different from bi-amping using any other amps.
A good read on the subject is here: http://sound.westhost.com/articles.htm
panomaniac
quote:
It is a little different because the small T-amps are bridged.
So it is important to stress that the negative terminals can not be tied together, nor to ground. Same for any amp like this. Also important to note that the Tripath chips will need 2 input caps even if you are splitting the signal.
Otherwise it is the same, yes.
Fin
quote:
Does this mean that if you have one set of input terminals connecting to a single stereo volume pot.....you split the signal before the input caps and have separate input caps for each amp (a total of 4 caps).....and that you cannot split the signal after the input caps therefore having one pair of input caps shared by both amps (a total of 2 caps)?
panomaniac
That is correct.
If you are not using some of the channels, they should still have an input cap (can be small) and be tied to ground for noise reduction.
Fin
Thanks Michael
I'm actually thinking of applying this to those little Lepai amps we are discussing in another thread.......and I assume it is the same principle............
panomaniac
Yes it is.
I'll be digging into a Lapai tomorrow to make a LF amp. Will build the LP filter right in - I hope! Going to try running it at 15 volts to see if it survives.
Fin
Can't wait to hear how you get on......
Do you still think that it compares well againts the S.I.?
And it is worthwile bi-amping a couple of them?
Buckapound
I have a question (maybe several) about active/line level crossovers.
Is it reasonable to make them passive? The treble could just use a high value input cap 1500pf(?) which would cut out all the bass to that amp, and the bass could use a cap to ground, which would dump all the treble and act as a low-pass for the other. Would this be good enough? It's certainly simple and cheap.
But then again, with biamping you would be driving two amps with a single source, changing the impedance and lowering the sound level (right?). So using a buffer/op-amp would help with that. But, finding good sounding buffer circuits that run on a 12v single supply seems to be an issue, especially for non-engineers like myself who haven't got the chops to design them for ourselves.
Thoughts?
--Buckapound
dgoodier
here is a very small active line level crossover adjustable from 50 Hz to 2.5 kHz.
rolls crossover
There is also the ibump on makezine.com for DIY. There is a schematic for the project, you may be able to bring up frequencies to suit your needs.
Tom, from quaketronics, that sells the ibump says that changing the six capacitors will yield different frequencies.
For lower than stock subwoofer freqs he recommended these:
Capacitor value: 0.068uF
Corner frequency: 99Hz
Digi-Key part number: P4523-ND
Capacitor value: 0.082uF
Corner frequency: 82Hz
Digi-Key part number: P4524-ND
Capacitor value: 0.1uF
Corner frequency: 67Hz
Digi-Key part number: P4525-ND
He arrived at the values by:
"The formula for the capacitor value is:
C = 6.715/F
where F is the corner frequency in Hz and C is the value in uF.
Or, the other way around works:
F= 6.715/C
This is handy because capacitors are only easy to get in certain values, such as 0.068uF, which is the value that we use. Other values that are available are 0.082uF and 0.1uF. Lucky for you the 0.082uF value gives a corner frequency of 82Hz, which should be close enough. The capacitors that you can easily get usually have a 5% or 10% tolerance. Use the 5% parts if you can get them."
ibump
panomaniac
quote:
Good enough for what? - would be the question. Not tying to be smart, just that you gotta know how you want to use it. ;)
Crossovers are, or should be, designed for the drivers and box you are using them with. One crossover is not going to work the same way with another speaker. Active or passive.
What you have described about is a simple 1st order active crossover. Yes, it will work well if the drivers and box alllow that type of crossover. Just pick the frequency you need.
Most analog active crossovers are built into the feedback loop of an opamp. That gives you a second order filter - 12dB per octave. They are easy to design and build. When you need a steeper crossover, you start to add these opamp filters in series. Flters like htis can also be made with tubes.
One cool thing about the T-Amps (and Hypex IIRC) is that the input stage is what? An opamp! So you can build your 12dB filter right into the feedback loop. Just add a cap and resistor or two and you have your crossover. Easy!
dgoodier That little Rolls crossover is cute! I had not seen it before. No telling how it sounds, as it has some obvious compromises. Only a single 12V supply (as mentioned by Buckapound earlier) and the simple twist knob frequency select. But it could be a fun place to start.
The iBump I've seen before, it's a nice circuit. I saw the schematic somewhere.
Back to Buckapound. Using a smaller cap in the T-Amp channel for the treble is something I've done a few times. Not really a crossover, but it does keep some of the bass out of that channel. Why amplify what you don't need? Means you can use a smaller, cheaper, better cap, too.
bikehorn
i'm very interested in this because i was planning a triamp setup using compression drivers for the mids and highs. as their efficiencies are 105 and 107 dB I concluded that 5 watts would be plenty of power for them...so i will probably either go with a pair of 41hz Amp32PS or modded 5066's...one thing i am concerned about is gain matching and i am wondering if there is a simple way to adjust gain on either of these amps. has anyone had any experience with this?
Fin
In this thread, Motherone talks about a resistor that adjusts the gain:
http://www.diyaudio.com/forums/show...7248#post567248
panomaniac
You want the gain to be "nominal" that is, both the input and feedback resistors are the same value.
I can't remember if there is an option for that on the AMP3. There is on the AMP6. The gain is a fixed little higher on the Sonic.
If you have a true fully active system what you will be doing is running these amps wide open and controlling the individual section (hi/mid/lo) levels at the active crossover. Your preamp does overall volume control and input selection.
If you are just Bi-amping/Tri-amping with passive crossovers at the speaker, then you might use the volume controls on the amp to adjust the relative section levels. Your preamp still serves as overall volume control.
Make sense? We need diagrams, don't we? :)
Fin
But if the amps are identical.......do we need to worry about separate volume controls or adjusting the gain? Can't we just use one volume control to control everything?
bikehorn
well, i do intend to match levels mostly through the outputs on the crossover but the crossover i planned to use has a boost/cut range of only 6 dB, so if the range were to be exceeded(due to the wide disparity in driver sensitivity as my woofer is 96 dB powered by 40 watts) i thought another option would be to pad the input of the T-amps. however i have read that adjusting the actual gain of the amp is better than using a pot or a fixed resistor pot. is this true? sorry if this is a stupid question...
Page generated in 0.055650949478149 seconds with 17 queries,
spending 0.00826311 doing MySQL queries and 0.04738784 doing PHP things.
Please support our sponsor.
