diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
T-Amp and Tube Preamp? - Click HERE for Original Thread
Solve
Anyone have any experiance?
Still think it needs a bit warmth.
Is there any cheap projects out there that could work and sound good?
raintalk
"warmth"?
http://www.bumwine.com/compare.html
Solve
Thanks for the serious answer in this topic...
:smash:
:D
Davet
I agree that the T-amp need a liitle warmth. I have my modfied SI T-amp connected to a Bottlehead Foreplay tube preamp. The tube preamp provides just the proper balance for this T-amp.
My 41HZ Amp6 does not really need the preamp. The Amp6 sounds warm enough without a preamp. It is a matter of taste.
Puffin
Solve. Do a search under "puffin" and you will find some infomation about this that I posted some time ago.
Solve
Puffin.I did a search and found some parts about tubes but not to specific?
Any recomendations out there?
Build your own?
Solve
This one looks cool!
http://www.autocostruire.it/modules...article&sid=103
BWRX
Change the input coupling caps (good mod) and slap on some aircore inductors and you'll probably get the warmth (a.k.a. distortion) you're after.
irss
BWRX, in your opinion, t-amp does not require any kind of tube preamp?
what about the need for extra inputs? Somehow I don't find this option very attractive:
http://www.tnt-audio.com/ampli/t-preamp_e.html
BWRX
I don't think it needs a tube based preamp, but they can certainly sound different with a preamp. Whether or not it sounds better is up to you to decide. I've used a very simple buffered volume control setup with a couple of TL072s from TI and think it sounds nice. I also tried NE5532 from Philips but it had a slightly different character that wasn't as pleasing to me.
I don't use my Tripath based amp anymore because the little D10.1 modules based on the MP7720 sound better :) I'd imagine part of that is due to the DC coupling (no input coupling caps). In the near future I'm looking to build an active crossover (with volume control) to drive the little modules, or any other amp for that matter.
Solve
Maybe i answer myself.
My old Marantz is not so bad.
Compared to those Class-D.
Its more music in it.
More warmth....
When my hype just stranded im not so sure anymore.
Maybe thats im asking for some tube, even if i dont now how its sounds?
Its just more easy listening...
I dont know...
Just a subjective report.
Solve
Solve
When im drunk the perception changes.
THEN my Marantz sounds better!
My T-amp sounds ugly.
So bright and demanding.
When i listen in my AKG 250 headphones
its sweat...
Music listenig is mood
and warthm!
When im clear T-amp is nice!
Still not sure.
Solve
Solve
Sorry mayby wrong forum.
Not an musical forum.
Im searhing for an good sound with an clear.
Im near with tripath with the dimension but not with the
warthm.
i answer myself-in realtime-i have to bad stuff around me!
Solve
Page generated in 0.032444953918457 seconds with 17 queries,
spending 0.00953341 doing MySQL queries and 0.02291155 doing PHP things.
