diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
intelligent semiconductor characteristic curve instrument - Click HERE for Original Thread
locky_z
I'm doing My Project is "Computer semiconductor characteristic curve" (My english is bad.So Just Show the test result.)
My project link(China) is http://www.hifidiy.net/bbs/boke.asp...owtopic.92.html
This instrument can test MOSFET / JFET / transistor / diode / SCR / resistance....
It can display the
1."Ic->Hfe" curve
Example 2SA733(PNP) "Ic->Hfe" curve:
and 2SA1386's "Ic->Hfe" curve:
2."Vbe(Vgs)->Ic(Id)" curve
example MTH15N20 "Vgs)->Id" curve
2SK246 Vgs->Id curve
3."Vce(Vds)->Ic(Id)" curve
example 2SC3519's "Vce(Vds)->Ic(Id)" curve
IRF9610 "Vds->Id" curve
4. 3-Terminal Regulator's Vi-Vo curve
Example 78L05
The Project use to matching Devices is very excellent
this pict show how to match 9 pair 2SK246s,It Test 9 2SK246s and Show their Vgs-Id curve
from the pict,you can see the 4 & 6 curve is match, and the 2 & 5
is match.
By this way ,you can match device precision.
The project use 5 integrate circuit, They's:
1 chip LTC1090(8 channel 10Bit ADC with SPI interface)
1 chip M62359 (8 channel 8 Bit DAC with SPI interface)
3 chips TDA2030 as 3 channels(B C E) programme Push-Pull Power Supply
1 chip 74HC595 as control relay
1 chip TC4050 with PC interface buffer
the instrument don't use MCU,just use PC's parallel port (LPT) to controle the DAC & ADC
john curl
Looks interesting.
jacco vermeulen
Locky-Z,
the link you posted to diyhifi.net does not work.
Can you post the link again ?
Are you willing to share the design, free or selling it ?
(you guys should install the Chinese language into your operating system, lots of great stuff on diyhifi.net, including top parts)
locky_z
the result is here
http://www.hifidiy.net/bbs/dispbbs.asp?boardID=2&ID=31462&page=1
the sch public here
http://www.hifidiy.net/bbs/boke.asp?locky_z.showtopic.92.html
but software is shareware.
I have a little LTC1090 & M62359 chips, just only enought to develope and use for me.
So the board is not sell.
jacco vermeulen
quote:
There is a ready made curve tracer software package ?
Not written in G or LabTracer ?
locky_z
the Circuit
Measurement of the curve, including :
BJT (including Optocoupler) :
PNP NPN of Hfe->Ic curve (measurement of the curve is in constant Vce conditions)
PNP NPN of Vbe->Ic curve (measurement of the curve is in constant Vce conditions)
PNP NPN Vce->Ic curve (constant Ib)
P-type or N-type MOSFET and JFET :
Vgs - Id curve (under the conditions of constant Vds)
Vds - Id curve (under the conditions of constant Vgs)
Diodes / Regulators diode / LED positive, reverse curve
positive and negative 3-Terminal voltage regulator IC:
Input voltage->output voltage characteristic curve
Output voltage->current characteristic curve liabilities
also capable of measuring SCR trigger current, voltage trigger, pressure drop, maintain current parameters (not curve)
Below are the same measurement a 2SC3519 high-power BJT curve
Ic = 300-1800mA scope of Hfe ->Ic curve
the IC=20-300mA scope of Hfe - Ic curve
Ic=2-30mA scope of Hfe - Ic curve
Ic=0.5-3mA scope of Hfe - Ic curve
Ic = 50-700uA scope of Hfe - Ic curve
The same 2SC3519 of Vbe-IC characteristic curve
Ic = 100-1900mA
Ic = 5-160mA
Ic = 0.3-14mA
Ic = 10uA - 1mA
Just look again at the output characteristic curve Vce->Ic
Ib constant measurement, Ib = 1-9mA
Ib = 0.1-1mA
Ib = 10uA - 100uA
Ib = 1uA - 10uA
locky_z
Below are the same screen shows 12 pic 2SA1386 of Hfe - Ic characteristic curve and Vbe-Ic curve and Vce - Ic curve
By the same measurement conditions , you can show more Semiconductor's curve on same screen.
From the screen ,you can match the most matching Semiconductor
Below is the measurement IRFI740 Vgs from 3V to 3.9V step 0.1V. measuring the Vds - Id characteristic curv
Below are the same measurement of the Vgs-curve Id (Id = 0-1700mA)
Vgs-curve Id (Id = 0-25mA)
Id = 0-1mA
Measurement of P-MOS IRF9630 the Vgs->Id curve
Measuring diode in a variety of different current of VF characteristics (1N5401 BYV32 FR305 1N4 001 MBR3060 1N4148)
Measuring 6 V Regulators diode positive / negative characteristic curve
locky_z
At the same screen to display the JFET's Vgs->Id and Vds->Id characteristic curve (2SK 373GR)
Let's look at different suffix of 2SK246 the Vgs->Id curve (GR and Y suffix)
Exchange the same 2SK246's D, S pin and measurement they Vgs->ID curve
The system also is a characteristic of different polarity to contrast the characteristics of the tubes, For example, the following is the system provides functional polarity reversal and contrast 2SK246GR and 2SJ103GR the Vgs->ID characteristics curve
Cliff Schuring
Does anyone know of any active links for Lock_Z DIY curve tracer and software. This project looks like a cool unit for using at home with out all the major expenses of obtaining a curve tracer from E-Bay. If not does any one know of a project using a USB measurement unit-( the cheaper ones) for doing this with say relays on the digital control ports.
locky_z
The schematic had changed a little,see below.
the software can download from
http://bbs.hifidiy.net/attachment.php?aid=246124
http://bbs.hifidiy.net/attachment.php?aid=246125
It is Chinese language version , only support one curve trace.
the board no MCU so it not support USB interface,only support LPT interface
Cliff Schuring
Locky_Z
I got the basics you sent and am working through some rough translation to better understand it. The site you have posted for the software can you give us a little more to navigate on since it seems to be all posted in Chinese. Is the software availiable ina code that can be edited for changing the language to make it a little easier for us that haven't learned Chinese yet? Thank you agian for all the info you sent out, still working through it.
Cliff Schuring
mightydub
quote:
Originally posted by Cliff Schuring
... If not does any one know of a project using a USB measurement unit-( the cheaper ones) for doing this with say relays on the digital control ports.
There was a curve tracer thread a while back where this unit was discussed:
http://www.circuit-ed.com/CT100-USB...acer-P17C5.aspx
I have no connection with the company other than I almost bought one, but got distracted with other things.
Cliff Schuring
MightyDub,
I looked at the one you saw also but was looking for a little more current and voltage capablity. Actually talked to the person at circuit-ed and found out that they are working on one that would do this but its not finished yet. Working at getting all the pieces together for Locky_Z's unit and working with it to see if I can get it working. Thank you for the site and idea.
Cliff
wakibaki
Last time I looked Windows programs had a resource file to make it possible to change such things as button titles independent of the executable. I could be mistaken, it's a long time, and Windows has changed, but if you're really interested I could poke into that stuff again...
w
'Course you need to know what the buttons should read.
ta2ctp
I need your following project :
(Schematic+pcb+firmware etc).
'' My project link(China) is http://www.hifidiy.net/bbs/boke.asp...owtopic.92.html ''
etc etc..
Can you help me ?
Because this link and sub are dead.
Please send following E-mail :
semicon@mynet.com
Thank you..
Best Regards..
ta2ctp
from Turkey
Page generated in 0.2123429775238 seconds with 17 queries,
spending 0.14009738 doing MySQL queries and 0.07224560 doing PHP things.
