diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
matching FETs and found leaking? - Click HERE for Original Thread
bigpanda
I have purchase some IRFP240 and 9240 from a distributor. When I try to match the 9240 by applying a 15Vdc and a 150ohm resistor in series with the D,S, I found some of them give me a steady ready of about 3.6-3.8V (+ or - doesn't matter) which is normal, but some of them (about 20/50) cannot sustain a steady voltage. Does it mean that these are leaking badly and are no good? I wonder if the distributor would do anything about it.
Thanks for shedding a light.
audioservice
Seems if the ones you suspect are leaky they should show some current when Vgs=0v. If it's gate to drain leakage, stiffining your gate drive should reduce the effect you are observing. Finally, if it's leakage it will be affected by temperature. As your IRFxxx warms up the leakage will increase.
Page generated in 0.017357110977173 seconds with 16 queries,
spending 0.00818491 doing MySQL queries and 0.00917220 doing PHP things.
