diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
need ideas about fe168sigma - Click HERE for Original Thread
woody
I just picked up a pair of fe168sigma not the new e sigma.
The amp that will be driving this has an output impedience of
~8 ohms. So the Qts of this driver using this amp will be about
.7 other than an open baffel what enclosures would work well.
Of paticular interest would be a knock down cab kit like the fostex
BK16 offered by Madisound. While I am talking about this driver
is there an easy way to calculate the value of resister capacitor and inductor necessary to flatten the impedience at resonance.
thanks
Woody
Scottmoose
www.zillaspeak.com/bib.asp would be worth using if you have rear walls, or better, corners. The Nagaoka D-37 would likely be worth checking out too, and there's a new double horn coming soon that I'm working out with Dave (planet10) that should do well with the old 168Sigma.
Bob also has an early MLTL design for this driver: http://www.geocities.com/rbrines1/Pages/Proposals.html scroll down toward the end of the page.
http://www.quarter-wave.com/General...l_Articles.html there's a few different BSC-related things here; an excel file too for calculating circuit values.
ChrisMmm
I can confirm the 168 works in both the Bob Brines cab (actually his FT1600 II cab which is pretty much identical) and the BIB cab.
I had them running in the FT1600 to run in - clean dynamic with good bass extension. Completed the BIBs yesterday and the 168s are transformed, incredible bass extension, big sound - yet to do any extensive listening but I would thoroughly reccomend the BIB cab for these excelent drivers.
Chris
Page generated in 0.020133972167969 seconds with 17 queries,
spending 0.00793481 doing MySQL queries and 0.01219916 doing PHP things.
Please support our sponsor.
