diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
what kind of relay is normally open but will close when triggered? - Click HERE for Original Thread
jarthel
would it be dpno? thank you.
mrshow4u
Most relays are NO (Normally opened). So you need a double pole? Sometimes they come as DPDT double pole, double throw. If you get DPDT, you can choose to connect to the NC (normally closed) of the NO (normally open) contacts. The other contacts will be the common connection. Here's a typical datasheet <http://pewa.panasonic.com/pcsd/prod.../pdf_cat/hc.pdf>
jarthel
thanks for the help
AndrewT
do you need double pole or would single pole do?
SPST are usually NO. and due to the single contatc are often rated at higher currents
Page generated in 0.016993999481201 seconds with 17 queries,
spending 0.00676632 doing MySQL queries and 0.01022768 doing PHP things.
