diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
OB Sub, which amp? - Click HERE for Original Thread
inrank
thinking of making an OB speaker (on my fullrage thread) and was wondering if there was a sub amp that would drive say 2 Dayton RS225's each side, or would i have to use one sub amp per channel, if i can, i would like to use the high pass filter on the sub for the FullRanger on top.
richie00boy
Well what is the impedance of the Dayton's? If they are 8 ohms each, you just need to find a sub amp that can handle 4 ohms, which should be easy enough.
inrank
you can get either a 4 or 8 ohm version, i have a sub at the moment, a Tannoy TS8, i guess its a 4ohm amp (200w), could i use that if it is?
richie00boy
Best stop guessing and take the Tannoy apart ;) It might have some other fixed EQ that you need to deal with though.
inrank
no idea if it has a fixed EQ.....
the drive unit measures 3.1 Ohms so i guess its 200w at 4Ohms
richie00boy
Good stuff. Is the Tannoy a vented box? Might be less likely to have some EQ then.
inrank
no, its sealed. :)
paulspencer
I'd go with 8 ohm versions, wire them parallel to get a 4 ohm load for each amp channel. Behringer A500 is a good choice. 230w into 4 ohms per channel. I doubt you would need more than this for OB use. If this were a box sub, then I'd suggest Behringer EP2500 with 650w into 4 ohms per channel or 1200 into 2 ohms. The latter amp has a fan and so would have to go in another room, or in floor/ceiling.
Page generated in 0.024250030517578 seconds with 17 queries,
spending 0.00910664 doing MySQL queries and 0.01514339 doing PHP things.
